Question about Compaq Presario Notebook
S video hookup tpo tv failing to connect tv to laptop via s video
    New Friend:
  • 50 Answers
YOu have should be a button on your labtop that is for a display. Usally use the combinations of CTRL and that button to bring up the options for your labtop to display on your TV also you can try seeing if there is a setting in your display in the control panel.
Posted on Dec 08, 2008
Tried to hook up a laptop to the tv and now the tv wont work at all.
what was the hookup HDMI, DB connection or USB..
Does the TV turn on still?
If it is on you probably need to go to setup menu and restore defaults.
.I have an LG plasma which sometimes freezes when I try to hook up laptop via DB connector..such a hassle to get it back sometimes ...have given up..
May 26, 2012 | Emerson Televison & Video
How to hookup all the units ,cable, vcr, dvd , tv.,and receiver
It all depends on what you have for inputs on TV really. Any video components should be hooked directly to TV via, best, HDMI, next, component. Component has great video but doesn't carry audio, for audio, you would have to use separate cable(s), digital optical being best. The best scenario would be to run cable/sat, dvr, etc, to TV then hook TV audio out, via digital optical, to reciever. You would use TV's menu to choose what you watch and, would have one audio out to reciever. Some, if not most recievers have video pass through but, it's not the best route and, you have more connections and more margin for error.
Jun 14, 2011 | Audio Players & Recorders
How to connect laptop to Panasonic TV LCD TX-L42U2B
Laptop to TV hookup all depends on what the laptop has for output to a monitor and what the TV has for input. Your laptop should have a monitor output, a 15 pin female jack. You need a cable (male to male) with these 15 pin connectors at each end to hookup to a TV with a PC input jack. For the audio, use a 3.5mm stereo audio cable. Hookup from earphone out on the laptop to the TVs PC audio input jack. If the TV has no PC input jacks, there are other ways to connect. See this link:
http://columbiaisa.50webs.com/laptop_to_tv.htm
May 18, 2011 | Televison & Video
No problem, wondering if I'm able to connect this TV to my laptop to connect to the internet and if so what do I need to do this.
Yes, you should be able to. You will need to buy a $20 adapter. Sewell Direct sells them, also Amazon.com. They are called VGA to RCA composite video converter. This will convert your laptop's VGA output to RCA composite video for connection to your TV yellow video input. Connect an audio cable from laptop's earphone output to the TV's RCA audio inputs (white and red) using a 3.5mm to RCA adapter cable available at Radio Shack for about $10. This will work. You can see everything that the laptop displays on the TV. You can even hookup a VCR to record it all.
Aug 04, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
HOOKUP A MAGNAVOX DVD/VCR PLAYER TO TV AND DISHNET WORK CA
may be your tv systems don't have an accessory for audio video input. but you can hookup that by using an RF modulator adapter, this is a converter from audio / video to RF signal and connected directly to your antenna connection. you can purchase that RF modulator adapter to an electronics store.
Apr 18, 2010 | Sylvania SRT2319 TV
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
PLasma tv
I believe that your satellite receiver should have video/audio output, if so; connect a yellow, red and white cables from there to the input on your plasma monitor and select video on the plasma to get ti to work.
Let me know if you need further assistance.
Dec 19, 2008 | Televison & Video
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Hd dvr
if you are connecting the dvr via component video cables select the output to 480i and not 480p or other higher formats.the tv cannot support anything higher than 480i. or try using composite video hookup instead.
Jan 29, 2008 | JVC AV-36320 36" TV
Compaq Presario Notebook Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
