Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Lamp burned Out
I have A Mitsubishi DLP television Model WD62725
Can You give me directions on where to locate the panel to access
the lamp.
Please tell me how to replace the lamp ( remove & replace)
  • 1 more comment
  • cmann497 Dec 08, 2008
    The repair manual is a good idea, but I understand this is a simple procedure, I just need to know how to locate the lamp in a
    Mitsubishi DlP Md WD62725
    COULD YOU pLEASE TELL ME WHERE TO Locate the lamp on a Mitsubishi DlP Television WD62725
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
For your requirement on how to replace the lamp, pls reference these instruction on comparable models:
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 08, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
  • 399 Answers
Http://fixyourdlp.com/blog/ click the above link also this another link to get the replacement new lamp http://www.discount-merchant.com/Mitsubishi-TV-Lamp-Original-bare-bulbs-s/231.htm
thanks.
  • 4,806 Answers
Replacing the Lamp Cartridge
Tool needed: Phillips screwdriver
1. Turn the television off and unplug the AC cord.
2. Remove the front speaker grill by gently pulling
on each side. The grill will snap out.
3. Using a phillips screwdriver, remove the three
screws (one on the left and two on the right side)
that hold the recessed plastic cover in place.
4. Remove the plastic cover and set aside
with the screws.
5. After removing the cover, you will be able to
see the lamp cartridge. With the screwdriver,
loosen the three screws of the cartridge.
The three screws will not completely remove .
6. Gently grasp the metal handle and pull
straight out (towards you).
7. Insert the new lamp cartridge securely
into the TV. Do not touch the glass surface
of the cartridge.
8. With the screwdriver, tighten the screws
on the lamp cartridge.
9. Replace the plastic cover and screws.
10. Snap the speaker grill back into place
by pushing it into place on each side
with the palm of your hand.
kind regards
    Genius:
  • 3,422 Answers
Please click on the below link to watch video on how to replace the lamp:
http://www.metacafe.com/watch/1225793/how_to_replace_the_bulb_in_your_dlp_or_rear_projection_tv/
  • 734 Answers
Download service manual from the above link -----
http://www.generalmanual.com/Televisions/Mitsubishi-WD-52825-1080p-DLP-Television.htm
Thanks
  • futureloginn
    futureloginn Dec 08, 2008
    Turn your TV off. Let it sit there for about 5 minutes to let the cooling fan help cool the lamp. Unplug your TV from the power let it sit about another 30 minutes. Even with the TV turned off power is still going to the lamp and the lamp receptacle can still be hot enough to burn you. Even if you think that the lamp is cool I recommend that you do not touch the receptacle.
    Usually the lamp has a cover that you will need to unscrew. Most manufactures use a Philips head screw for holding the cover shut. Unscrew the lamp cover.
    Unpackage the replacement lamp. Be careful not to tough the glass, as oil from your fingers can damage the lamp's surface.
    Pull the lamp out. Most lamps have a plastic tab or hoop on the handle that you can use to pull it out. Follow the owners manual for specific instructions on how to pull the lamp out. Make sure you do not touch the surrounding lamp housing if you just turned off the TV. It can burn you if it is hot.
    After the lamp has cooled, place it into the empty box of the replacement lamp. Never put the used lamp into a plastic bag.
    Using the guiding post also called "gutters" by some manufactures slide the lamp replacement lamp in pushing it until you hear a firm click.
    Screw the lamp cover back in.
  • Mitsubishi Master
  • 13,433 Answers
WHERE CAN I FIND THE BALLAST IN THE MITUSUBISHI WD 52532 MODEL
hint: the two pins the lamp plugs onto go directly to the ballast which is really a power supply for the lamp.
not clear from all you have said if ballast is the problem===these sets had a lot of issues; anything, even too much dust on the fans inside will shut it down...........
Mar 26, 2012 | Mitsubishi WD-52531 Television
Lamp changing Instructions for tv model wd-52525
Hello
Unplug your Mitsubishi DLP TV and position the unit so you can easily access the back
Locate and remove the screws for the back panel. Do not remove the entire back of the TV but the lower panel only. The screws will be located in the edge of the panel.
Locate the projection box in the center of your DLP TV. The projection box will have a series of wires coming out of it and be attached to the speaker housing with four screws
Remove the four screws holding the projection box in place and slide the projection box out. It will not come all the way out but will slide out like a drawer. Disconnect the electrical wires at the projection box by pulling the connectors apart. You should now be able to see the projector lens itself.
Facing the back of the DLP TV, the lamp box is on the right side of the projector lens. Pull the lamp box to the right and it will slide away from the projector lens
Grab the top of the lamp box firmly and pull it out of its spring holding clips. Replace it with your new lamp box by pressing the new box into place in the same manner as the old one. Finish the job by reconnecting and installing everything you opened or removed
Mar 18, 2011 | Mitsubishi Televison & Video
My 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Feb 20, 2011 | Mitsubishi Televison & Video
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
Mitsubishi WT-42311 DLP Bulb Replacement
Your access should be a a panel near the back or side. You will see that it is somewhat easily removed and should have maybe one or two screws. You will see the casing to the lamp. Go ahead and remove it. Now unscrew the old bulb and replace it with a new one. There is not a lot of screws holding it together. It's a fairly easy process once you find the lamp. You should see the lamp once the panel is removed.
Jan 14, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD62725 Lamp
code 34 is lamp abnormlality which what you are discribing is most likly the balast, since the lamp comes on for a brief second then shuts down. the part # 939P978010
Jan 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
