Question about Frigidaire FDE336RE Dryer
How to take the back off frigidaire fde336res2
We are trying to check the heat element and can not get the back of unit off.
I have already replaced the element on mine, i dont believe the back comes off, you have to unpop the top, unscrew the front, go to the back, theres a little vent looking plate,unscrew that, in there unhook that little spring, take the belt off, go back to the front, lift the drum straight up, take it out, whalla theres the element. good luck
Posted on Dec 10, 2008
How do I replace the heating elembent in a frigidaire FRAM18ER2A ac/heating UNIT
This type of unit does not normally have a heating element, it is a heat pump. In summer if blows cold air through the front and hot air out of the vent at the back. In winter, cool air is drawn in through the back, heated by the compressor and vented out of the front vents.
The manual is here. It seems Frigidaire Service is the only answer.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020219A0576en.pdf
Wiring diagram is here. The unmarked item, 2/3rds down on the left may be an element.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/202021990031.pdf
This intimates it has a 4000 watt to 4900 watt element depending on voltage supply.
Voltage Rating: 240V / 208V 60Hz
Amps (Cool): 8.4 / 9.2
Watts (Cool): 1900 / 1880
Amps (Heat): 22.2 / 20.0
Watts (Heat): 4900 / 4000
Horsepower (Cool): 2.49
Power Cord Length: 5' (6')
Plug Type: 6-30P
Despite my best searches I can't find anyone selling gthe element. Try these two companies though
Frigidaire Refrigerator Heating Element Parts: Fast Shipping
https://www.repairclinic.com/Shop-For.../Frigidaire-Refrigerator-Heating-Element-Par...
Looking for parts for your Frigidaire Refrigerator? ... Frigidaire Refrigerator Garage Heater Kit. ... Frigidaire Refrigerator Defrost Heater Assembly.
Missing: fam18er2a
Frigidaire 137488301 Heating Element (10 - AppliancePartsPros.com
www.appliancepartspros.com › Frigidaire › Washer › Frigidaire Washer Parts
US$65.40
HEATING ELEMENT (10 137488301 / AP5618485 made by Frigidaire.
Missing: fam18er2a
Nov 16, 2017 | Frigidaire Heating & Cooling
Trying to replace heating element in my frigidaire dryer model# fde336res2. where is the darn element? thanx kevin
Hi awc9859...
Your heating element is behind the drum where it is attached and case of the dryer
I have also attached a link so you could view the part in its location...double click on the drawing and look for part 15.
Please take time to rate me thumbs up
http://www.partselect.com/PS418120-Frigidaire-131553900-Heating-Element-Assembly.htm?SourceCode=5&ModelNum=fde336
Sep 10, 2011 | Frigidaire Dryers
My Frigidaire GLEB30T8CSA top oven lower heating unit isn't getting hot, I checked wires coming to heating element one side shows 120v but the other side does not, so I think whatever that wire hooks to is...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 18, 2010 | Kitchen Ranges
How do i replace the heating eliment? frigidaire fde336res2
i don't know what model You have so i will give you this link appliance repair video’s
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "h_WMwQ-M33A" placeholder (do not delete)
Dec 29, 2009 | Dryers
Frideraire dryer model fde336res2 won't eat. The
Take a look at #36 in the breakdown I have attached. This part is called a thermal limiter and blows if the heat is restricted in any way to cause the dryer to get too hot. You need to make sure that you don't have a lint buildup around the motor and in your vent hose. The part number for this part is 530320912. Hope this helps.250
Nov 19, 2009 | Frigidaire Dryers
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
My frigidaire heavy duty dryer model number FDE336RES2, starts to squeak once it turns on. It will continue to do this until it warms up then it stops. How do I fix this?
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does? SOME PICTURES
Sep 07, 2009 | Frigidaire FDE336RE Dryer
Dryer will not heat up
check that you didnt disturb any wireing by mistake. then chec the contunity on your heating element. they are actually pretty fragile.
Apr 25, 2009 | Frigidaire FDE336RE Dryer
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Wiring diagram
check this and see if this helps you out http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1428&modelDesc=FRIGIDAIRE/FS%20DRYER%20-%20P5995326211&modelNumber=FDE336RES2&documentID=Y2705791&documentTypeID=PLDM&documentClassCode=PM&titleType=131850300%20WIRING%20DIAGRAM&titleID=00006&
Oct 08, 2007 | Frigidaire FDE336RE Dryer
Dryers Logo
751 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
