Question about Sharp Audio Players & Recorders
How to set my audio to hdmi while connecting my tv to my pc. my graphic card is Gforce 9600
    Problem Solver:
  • 17 Answers
I am pretty sure that the nVidia GeForce 9600 series of video cards use a DVI connector, not an HDMI connector.
While the HDMI connector has the ability to transfer digital and analog audio across it, the DVI cable does not.
You can connect a DVI video card to an HDMI display, and it is compatible for the VIDEO portion, but again, the DVI connector does not output audio at all.
You will need to connect the audio outputs of your audio card or motherboard to your TV by using a 3.5mm headphone jack to RCA jack adapter.
Posted on Dec 09, 2008
How to connect asus p1801-t to tv ?
This PC is equipped with a NVIDIA GeForce GT 630 2GB DDR3 VGA/DVI/HDMI PCI-Express Video Card. This means if your TV has an HDMI input connector you can directly connect the pc to the Tv with an HDMI cable and select the corresponding graphics monitor connection in the Display properties. Alternatively if your tv has only got a VGA input that can also be used from the PC and you can connect the speaker or headphone audio output to the audio input of the TV with a suitable 3.5 headphone to RCA adapter.
Aug 24, 2014 | Computers & Internet
S-video out to tv nvidia 9300 gforce won't work
obvious things first. have you tried the other input plugs on the TV? do you get the same problem with plugs 1 and 2?
you can try only having the TV connected to the Graphics card and turning on the PC see if it comes up as the primary display automatically.
have you tried configuring the Nvidia setting so ONLY the tv is a display instead of dual monitor?
doing these will rule out faulty cable or faulty S-video plug or Faulty TV input plug.
Dec 07, 2012 | Nvidia 64MB GeForce3 AGP Video Card with...
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
May 12, 2011 | HP Pavilion m7570n (EX331AA) PC Desktop
My Pc just shut down while i was playing a game. i unplugged my geforce 9600 gt's power and my pc worked again, but without graphics. what is wrong with my graphics card???
The problem that caused the PC to shut off is the GForce graphics card is drawing too much power and the switch mode power supply was overloaded and shut down.
Check the switch mode power supply's wattage, if it is around 300 to 400 watts, it maybe be too low. You most likely need to get a higher wattage switch mode power supply, especially if you added more RAM, disk drives, DVD drives etc. to your PC after the initial purchase of the PC.
Feb 12, 2010 | BFG Technologies NVIDIA GeForce 9600 GT OC...
Problem connecting gforce 8600 to philips full hdtv
hello sir
how r u
my problam
inbox my laptop model # M27ES made in china not vga driver instal
plz sand me vga driver for this model & company
thanku
Mar 25, 2009 | Philips TV / PC Video / FM Graphic Card
I have a new HP Pavillion Elite m9160fPC with HDMI- no sound
you have to change your Realtek Audio settings to HDMI output under "playback devices"
Mar 23, 2009 | Computers & Internet
Gforce 9600 gt on a aspire t180 pc?
Yes, of course. don't worry! It will be far better than the integrated video your PC has.
Jan 03, 2009 | Computers & Internet
How to Hook up ATI 9600 to PC
Did you switch the TV input to S-Video on the TV control panel (usually accessible via the remote)? You will also likely need to fit a 1/8" (mini-headphone jack) connector from your PC to RCA (Red and White audio standard) connectors on the TV - this cable can be purchased in many places. The S-Video connector doesn't carry audio like an HDMI connector will.
Dec 16, 2008 | Abit AGP Video Cards: /ATI 9600XT 256M...
Ati 9600 all in wonder- no sound when using tv componenet.
The TV portion uses the audio input on the sound card in the PC.
Sep 05, 2008 | ATI ALL-IN-WONDER 9600 (128 MB) Graphic...
69 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
