Question about Olevia LT27HVX 27 in. LCD Television
HDTV says "No Signal" when there is one
I have an Olevia 27-inch TV, and I recently hooked up an Olevia Blu-Ray player to the television through an HDMI cable. When I play a movie, I get a "No Signal" message displayed in the bottom corner of the screen, but the movie is playing just fine.
It's good that movies play on my TV, but why is that message appearing when there clearly IS a signal? I assume it has something to do with the HDMI output. Can anyone help with this? Thanks!
  • 1,199 Answers
You may have to go into the menu of the player to change the setting!
Posted on Dec 08, 2008
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
How do I hook-up a blue ray HDMI to my AKAI HDTV thru a digital cable box?
If your TV doesn't have an HDMI port on it then you'll not be able to use the player. Some players have hi def output jacks, but it isn't true HDMI so using a hi def cable would defeat the blu ray players resolution when viewing a blu ray disk.
Nov 17, 2014 | Televison & Video
HDMI audio cutting out
Sometimes it might be the TV, sometimes it might be that HDMI cable having issues with that certain TV. Your best bet would be to get another HDMI cable and see if that helps.
Nov 05, 2013 | Sylvania Televison & Video
I can't figure out how to connect my blu ray player to my Olevia 542 tv
whatever the player uses --Component (blue-green-red) or composite or HDMI for output connect to the correct and identical input on the rear of the set----switch to that input and see what you have.
Nov 04, 2012 | Televison & Video
I have a 27" RCA TruFlat TV. Recently the picture
Something has definitely gone wrong. When picture fails, generally the audio will still play; but since the set is shutting down completely after a short time - it is going to more involved.
Firstly, anything can be fixed. The questions to ask are: 1) At what point do you stop spending money to repair a device that is XX years old? 2) How much would a replacement / upgrade cost?
Given that your set is an older SD (standard definition) with an old analog NTSC legacy tuner, it may be worth while to make the move to a digital HDTV. The picture quality will "blow away" any SD version of the same image / program that your old TV displayed. Unlike several years ago, the HDTV has come way down in price, too. A 32 inch, wide screen HDTV price starts at just $235 as results shown by a search in Google. In order to view HD signals, you'll need either 1) a plain UHF/VHF antenna (and local broadcasters in range), 2) HD cable TV service or, 3) HD satellite service. Cable and satellite providers offer SD service and for slightly more, HD service. Most people are not happy watching SD signals on an HD display - so you'll probably want to change the level of service if you're not using an antenna. Old DVD players only send SD signals, you might consider upgrading to a Blu-Ray player. Blu-Ray players provide SD and HD signals - depending on whether you insert an SD DVD or an HD Blu-Ray disk. The Blu-Ray players, like the HDTVs, have also dropped in price significantly.
See if you can find a place that provides free estimates. If not able to locate, find someone that will apply the cost of diagnostics (ask what the diagnostic fee is) to the total repair charge, and decide to either fix or replace.
I hope this helps and good luck! Please take a moment to rate my reply - thank you.
Feb 25, 2011 | RCA TruFlat 27F520T 27" TV
Plasma tv showing "Mode not supported" message
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Hooked dvd player up to my olevia tv and don't know what channel to set tv on to watch video. checked all the channels - can't find movie. do i need to change a setting?
U setup ur DVD player in what format?Set it up with a one cable call HDMI?Or u use a RCA cable YELLOW.RED,WHITE to hook it up.The movie play,u push the button on ur remote said INPUT go down INPUT said 1,2,3 so on.If hook it up right the movie,should play in one of this INPUT said 1,2,3 so on.
Apr 02, 2010 | Olevia LT27HVX 27 in. LCD Television
New HDTV...using RCA Anttena hooked it up
Buy digital antana,get stronger signal,will work for any wheather.
Feb 02, 2010 | Olevia LT32HVE 32 in. LCD Television
When trying to connect my 4695D to a new Sony Blu Ray player BD 560 using HDMI with the output set on the Blu Ray to 1080P I cannot get a signal to appear on the TV. If I change the output to 720P I am...
The problem has been solved. A previous post to this site was having a similar problem hooking up a Playstation Blu Ray player to the same TV.
A solution was posted to that problem and I followed the same instructions.
It has to do with the set up porgram on the Blu Ray component. You need to select Settings then 108024Bit needs to be set to off.
Dec 28, 2009 | Samsung LN-S4695D 46 in. LCD HDTV
Olevia LT27HVX 27 in. LCD Television Logo
330 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
