Question about LG WM2688HWM TROMM SteamWasher
ERROR NOT DRAINING
LG WASHER WM2688HWM has an error message saying the washer is not draining I need to check the drain and/or filter. I checked the drain and it isn't clogged. Where is the filter, so I may check it?
  • porsche917 Dec 14, 2008
    lg wmo642hw front load washer, drain filter is clean still will not drain
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 42 Answers
The filter is located right after you open the drain cover on the bottom of the washer it's a hard plastic filter, if it is not clogged with any debris, then it sounds like your pump motor is bad, maybe need to replace it. lg's are very sensitive........., find out the part number and search it through google. if not email me and i could set sumthin up for you.
drsn777@hotmail.com
dave
Posted on Dec 12, 2008
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
Oct 24, 2015 | LG WM2301HW Front Load Washer
Washer wont drain displays OE. Pump makes a vibrating sound lie it is plugged already checked filter cleaned it removed hose how do you replace the pump?
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. If the issue returns then yes you should replace the pump, please check this repair manual on how to replace the pump. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | LG WM2688HWM TROMM SteamWasher
Washer machine erroe code oe
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Clean and straighten the drain hose / clean the drain filter.
Jun 30, 2010 | LG WM2688HWM TROMM SteamWasher
How to clean pump filter on lg wm2688hwm
No, probably have a bad water pump, very common for this washer. I would pull the washer out, lean it against your wall, brace or block it up so you can crawl under it. You will see where the drain hose comes out of the bottom left of the drum and enters the drain filter. Remove the hoses and check for debris or clothes in the hoses or where the drum outlet is. If no restrictions then replace your water pump. Good Luck, Appliance Specialists
Dec 20, 2009 | LG WM2688HWM TROMM SteamWasher
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Lg wm2277hw
You do not have an "OE" error, you have a "DE" error. DE error is "drain error" which displays if the washer has not pumped out after 10 minutes. If there is water in the machine and no obstruction in the filter I would suspect that the pump impeller is bad, and you would need a new pump motor. (part # 4681EA2001D) Pump motor is located directly to the left of the filter, and can be accessed by tilting the washer back and reaching it from underneath. The pump housing is held onto the machine by three phillips head screws.
If you have "DE" error and there is no water in the machine that's a whole different problem I'll address if you say that's the case.
If you need good service, try calling a small dealer who sells and services the procuct line you are having a problem with. You can find LG servicers at us.lgservice.com but avoid the utility companies, A & E, Sears, and all the big guys who try to service every brand but often times are not very familiar with your brand.
That should help. Carl S., factory authorized LG technician for over 10 years.
Aug 25, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
547 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
