Optimus lab 1100 fully automatic turntable playing too fast
After a recent move I threw a record on to my turntable and got through one side and halfway through the other... and then mid song the Beatles turned into Alvin and the Chipmunks.
I can see any real damage to the player and the belt looks ok.. but is this a sign that its about to go? Is there any other reason this may be happening?
  • 5 Answers
SOURCE: Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Posted on Sep 18, 2008
SOURCE: How to remove platter on Optimus Lab-1100 Turntable
on the shaft in the center where the hole of the record goes there is a locking washer on it . you can carefully remove this with a thin knife of something similar . you may need to use a little force , it is on there pretty tight however it can be removed .good luck
Posted on Oct 26, 2008
  • 104 Answers
SOURCE: optimus lab 1100 truntable will not operate.
this is a belt driven platter. the belt is old and fell off. http://www.archive.org/details/Turntable_Belt_Installation
this link shows how to replace a belt, once you see where the belt goes thread a piece of string through the mechanism where the belt should go and measure it and contact them with the length. or measure total length of the old belt if still in one piece. figure about $14 for most belts.
Posted on Feb 11, 2009
SOURCE: One of my technics' 1200 turntable's tone gets too high
This appears to be a slight difference with the manufacturing lots that your turntable came from Technics (Panasonic). The pitch control is to set the speed for the varying AC Frequencies (Hz) available in the world. Set the speed for the Hz your local area electricity provider uses 50HZ for 50Hz and 60Hz for 60Hz. Once the "Pitch control" is set for the local Hz don't bother playing with it unless you want the interesting sounds from the turntable. As your other turntable's speed is increasing, the pitch is increasing as well but your ears haven't noticed the different tones since they are lower in Hz. I.E. the male Bass or Alto voice is lower in tone than a female Soprano voice, and when you speed up the two differing voices the one noticeable higher is the Soprano.
Posted on Sep 18, 2009
SOURCE: I have an Optimus LAB - 1100 automatic turntable i
stopped working - i took turntable apart - the wires controlling start, stop & cue are loose. i don't know where to reconnect them.
Posted on Jan 24, 2011
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
My Optimus LAB 1100 is playing 45s ok but the 33s sound like the chipmunks
the turntable speed is incorrect
adjust with the speed control setting
many quality turn tables have bar codes around the outside edge and when viewed under a light those bars appear to be stationary when the correct table speed is set
It is a strobe affect in time with the frequency of the light
Dec 06, 2015 | Audio Players & Recorders
HOW TO INSTALL A BELT ON A OPTIMUS LAB-1100 FULLY AUTOMATIC TURNTABLE
See:
http://www.youtube.com/watch?v=FTJd_WbEhEs
If you have difficulty lifting the platter off, raise it as far as you can and gently tap the spindle with a sift-faced hammer.
Sep 23, 2014 | Audio Players & Recorders
Connect optimus lab 1100 to macbook
The type of computer is not relevant. This turntable provides output at nominal "line level" and can be connected to your MacBook with a properly shielded audio cable through the audio input.
For best results, you might want to disable automatic-gain-control (AGC) in the "Sound" preferences pane in the "System Preferences" panel, and set the level manually such that the input does not overload.
As I mentioned above, the signal level is nominally "line level", and that can mean very different things depending on context. You might find that using a passive volume control (potentiometer) between the turntable and the computer's analog-to-digital converter can greatly improve the quality of sound.
Jun 20, 2014 | Apple MacBook Pro Laptop Computer with...
My crosley portable turn table will start but half way into a record it stops spinning; please advise
There is a small motor under the turntable that either uses a belt to turn it or has a rubber tired roller that sets up against it and spins. You will probably be able to find a belt or rubber wheel at a TV repair shop. Some models had an adjustment on them and can be adjusted but more than likely you will need a new belt or rubber tire. The tires looj like a big square :O: Ring
Mar 12, 2014 | Crosley Audio Players & Recorders
Stereo Record Player Stopped on Eject
Try rotating the turntable but stop if you encounter a lot of resistance. It should turn easy and the arm should move. If it does your motor might be bad.
Dec 23, 2013 | Audio Players & Recorders
How do I replace needle on Optimus Lab 1100
The manual for the Optimus LAB-1100 can be found here: http://support.radioshack.com/support_audio/doc63/63393.pdf
Replacing the needle is on page 13. I did it and it was easy.
Cheers, Gordon.
Dec 18, 2012 | Audio Players & Recorders
264 people viewed this question
 Grubhead
Grubhead
