Question about HP Compaq WF1907 Monitor
Connecting a Compaq nx6310 laptop to a bigger monitor
Trying to connect my laptop to a Samsung 204b monitor and screen does not pop up on the new larger monitor....what do I do ? Is there some sort of disc driver needed to transfer screens over ?
Thanks
    Sergeant:
  • 236 Answers
Should be Function Key and F4 (or a similar FKEY will show a monitor screen)
Press 1x to push image to ext. monitor
Press 2x to have dual display
Push 3x to just have laptop screen
Posted on Dec 08, 2008
My samsung q320 will not detect my projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Jan 12, 2013 | Samsung Q32032P PC Notebook
Can HP Compaq nc6320 monitor work on the nc6230 laptop
you will need to connect the monitor to your laptop to create an extended desktop usually the monitor connection is on the side of a laptop
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or you might have to
click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
hope this helps
Jun 26, 2011 | HEWLETT-PACKARD Hewlett Packard 413671-001...
Start up problem with Samsung Sync Master 731BF 17" monitor
Your internal power supply is failing. There are parts called capacitors that are not functioning correctly and this causes the power supply to not be able too stabilize the voltages that run the monitor. After repeated power cycles the capacitors will hold enough charge to function until you urn the unit off and then they discharge so you have to start all over again. We have a step by step repair guide article posted at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ This should get you back going again. If you don't want to do the repair yourself we do offer a repair service, you can get that information here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Compaq nx6310 power up but no video
Hello devilgod1209,
The memory and hard drive shouldn't be the issue. Most likely your LCD has stopped working or the inverter for the LCD panel's back light has stopped working. Try shining a flashlight directly at the screen and see if you can see any windows, icons, etc. If you can then the back light has gone out or the inverter has failed. If you still don't see anything your LCD panel may have failed. Try hooking up an external monitor and see if you can get an image to display on it. If so then you may need a new LCD panel installed. At that point you should probably take it to a repair facility or see if your warranty will cover the replacement.
Hope this helps and good luck. Don't forget to vote and leave feedback.
Feb 16, 2010 | HP Compaq nx6310 Notebook
Only getting 1/2 screen upper half black
Try connecting the monitor to a different computer.
If you get the same symptoms, take the monitor to a qualified technician -- they probably will charge your $25, and then tell you that the electronics inside the LCD are damaged, and that you'll need to replace the monitor. Instead, exercise the "warranty" on the monitor, to get it replaced, or "invest" the $25 "inspection-fee" as part-payment of a new monitor.
Jan 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B The blue power button is on but the screen is black. When I turn it off and back on it shows the screen for a second then goes black. Can you please help me. Thanks
Got the same problem, happened yesterday for me, Did some research and it looks like its bad capacitors in the back, check out this page for more information... i'm taking mine to an electrician to fix today... luckily he's related and should be able to fix it on the cheap...
http://pavel.kirkovsky.com/blog/2009/03/samsung-syncmaster-204b-repair/
Apr 02, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung Syncmaster 204B
Try to replace C110 and C111 in the power supply circuit. These are 820uF caps and are in parallel. I had slow start and a flicker on this same monitor. Replacing the caps fixed it. Good luck, Ryan
Jul 09, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Connecting samsung monitor to my laptop
Assuming you are connecting the mointor to DVI or VGA cable. You can connect the monitor through windows. In vista, right click, personalize, display settings, You should see a greyed out monitor. Click extened the desktop onto this monitor, It should automaticaly detect itself.
In xp its similar. Right click on desktop, go to properties. You should see a screen pop up. Go to the last tab. it should be monitor. Click on teh greyed out area and click Extend the display to this monitor.
May 30, 2008 | Acer TravelMate 4200 Notebook
HP Compaq WF1907 Monitor Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
