Question about Envision EFT720 (Black, Silver) 17 in.CRT Conventional Monitor
Monitor trouble I purchased a game for the pc, After everything installed, I put in disk 1 my screen goes black then comes up with this ATTENTION OUT OF RANGE H:75. OKHz V:74.9 hz Game will not do anything except sound. All other games work. Is it my monitor, or the cd. Any help would be greatly appreciated. Thanks Bob Harrison
    New Friend:
    Problem Solver:
  • 5 Answers
It means your system display card settings are too high for your monitor. Try to change the refresh rate of your monitor
Posted on Aug 22, 2017
antiochpc
  • 1314 Answers
SOURCE: help
It does indeed sound like a backlight problem. Generally speaking, the expense in finding a new backlight and having it fixed isn't worth it considering a new 19" monitor can be had for $150.
Posted on Jun 11, 2007
  • 5 Answers
SOURCE: help
If the monitor was dropped, most likely you damaged the internal components that provide the picture, whether LCD or CRT. Try connecting it to another computer. If this doesn't work, check the monitor's display settings or operating system display settings for contrast or brightness. NEVER open up the monitor, because there is a high voltage capacitor that stores voltage even when the monitor is off and could kill you if it discharges.
Posted on Jul 28, 2007
  • 55 Answers
SOURCE: Make sure Resolution is 1440 x 900......
hello,
did your monitor support 1440X900 resolution. if yes then go to desktop properties then change the resolution to 1440X900 then play the game.
if not support then remove the game from your pc.
ramesh
Posted on Nov 29, 2008
budmrtn
  • 11361 Answers
SOURCE: frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Posted on Jan 12, 2010
  • 41 Answers
SOURCE: Input Not Supported
Yes, you can try reducing the refresh rate to 60 Hz.
You can change this option in Display option in control panel.In the display proreties dialog box under settings tab,click on advaced button.click on Moniter tab.there you can find screen refresh rate option,change it to 60 Hertz.
This would solve your problem.
Posted on Feb 14, 2010
Testimonial: "The advice was helpful. I will see if his solution works. If so, his advice was very helpful and he should be commended for his knowledge."
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
Samsung SyncMaster 2232gw unstable
It seems from the begining you have had nothing but trouble, if under warranty return the item, because it will eventually fail, it is a matter of probability.
Apr 22, 2012 | Computers & Internet
Blue screen with error
You'll need a system repair disk or operating system disk to fix this problem. Put the disk in the cd drive and boot from it. You want to get to a dos command prompt (black screen with white letters) so that you can type in the following command: chkdsk /r
Check Disk will run well over an hour so be patient. You will even see the percentage of completion going from high to low but that is normal. Just let it run to completion then reboot.
In windows xp you get to the command prompt by doing a repair when you see the options come up from the system disk.
In vista you get there from the recovery console and you will see the dos command box at the bottom
If Check Disk does not solve your problem you'll need to reinstall windows. You can do a repair install which will preserve your docs, music, pictures and videos. A clean install will wipe out everything.
Also System Recovery wipes out everything and sets your computer back to the state it was when you first purchased it.
Mar 22, 2012 | Computers & Internet
Screen goes black with one cursor blinking after windows loads
start your pc press del, go to cmos setting and look for primary and set it up to boot from cdrom
after you install everything
go back to the cmos and put it back in primay hardrive and that is IDE1
Aug 04, 2009 | Dell Dimension 2400 PC Desktop
My PS2 Slimline goes black or freezes or skips during gameplay.
No you prolly dont have a warranty at all. I dont on my refurbished disk. As far as the game not playing it has to do something with the Cd. Alot of times the people that sell the disk send it through a certain kind of scanner and it erases or screws up the CD somehow. U might wanna take it back and get it replaced if its not to late.
Dec 29, 2008 | Sony PlayStation 2 Slimline Console
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
Fixing BD movie disk on UK Ps3
Try a Blue Ray lense cleaner dont where to get
Sep 15, 2008 | Sony Playstation 3 (PS3) Console
Monitor goes black suddenly
nvdia 6600 requires a minimum of 450 Watts of power to ensure that everything works properly. So if you want to continue using your nvdia card, an upgrade will be necessary.
If you want to test to see if it is the nvidia card, you need to remove the card physically from the system, then boot with the onboard video. This action will eliminate any conflicts between the two video cards. Before doing this you may need to go into device manager and make sure the onboard video card is not disabled.
Jul 26, 2008 | Gateway 838GM (RB838GM) PC Desktop
Envision EFT720 (Black, Silver) 17 in.CRT Conventional Monitor Logo
51 people viewed this question
Top Envision Computers & Internet Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Andrew Taylor
Andrew Taylor
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
