Question about GE Spectra JGBP35 Gas Kitchen Range
Low Heat from GE XL44 gas range
I have an old XL44 GE gas range (JGBP35WEA2WW). Burner ratings (as per manual) are 1 x 5000, 2 x 9500, & 1 x 12000 BTU. The unit is around 9 years old. We feel that it cooks and heats too slowly. We are looking to buy a new range, but most of the models I see have similar BTU ratings. Could this be a problem with our current range? Should I expect similar heat from a new range of similar rating? Any other factor that influences heating from burners?
  • amit3401 Dec 31, 2008
    Thanks a lot for the advise. The model has fixed (non-adjustable) orifices. But I just cleaned it for now. Thanks.
  • 171 Answers
You can increase the sides of the flames by opening the orifices, if not differences. make the orifices holes a bit bigger, you can have as big of a flame as you want. those orifices are at the connection of the burner with the valve that supplies gas to the burners.
Posted on Dec 09, 2008
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
    If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
    Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
    Xl44 oven burner pulses, doesnt properly heat up.
    it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
    Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven burner makes a popping or whistling sound during baking cycl
    You have a gas leak in the oven.
    Get this fixed immediately.
    Feb 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Natural Gas to Propane for Ge xl44 Gas range
    The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
    your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
    Jan 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Similar problem but ignitor replacement did not fix mine
    try the gas valve behind the storage drawer. it may be closed. that was my problem.
    Aug 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Spectra XL44 Model# JGBP35DED4BB
    Oven sensor or thermostat most likely bad
    Jan 02, 2018 | GE Spectra JGBP35 Gas Kitchen Range
    Stove top pilot light
    I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
    Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE XL44 Gas Stove
    Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
    Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Spectra JGBP35 Gas Kitchen Range Logo
    804 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
