Auto sensing input
I own a mitsubishi dlp model 65835. I have only had the set for a month and out of no where, the auto input sensing screen appears telling me that it has sensed something in input 1. However the only thing I have connected to the set is an HDMI cable. If I hit the input screen and reset to the HDMI selection the TV comes back on. This is a random situation that has no pattern of occurence. Help
  • Anonymous Jan 06, 2009
  • 10 Answers
SOURCE: Trouble with my Mitsubishi VS 50609
Make sure you have no colent leking on the bord these set many I worked on had colent leaks that cused it to shut down. does the set come back on when it's cool? could be a bad soder joint. allso there could be bad caps. deos it come back on if you unpluge the set for 5 sec and plug back in that resets the set.
Posted on May 21, 2007
SOURCE: Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Posted on Jan 27, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
Posted on Jan 05, 2009
  • 10 Answers
SOURCE: Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Posted on Feb 10, 2009
  • 10 Answers
SOURCE: No auto setup display on TV
For the setup functions you have to use either the monitor out (a yellow jack on the top-right corner of the back) or you have to use component video out. HDMI will NOT work for setting up the system. This is one complaint to Yamaha from all of us.
Posted on Feb 20, 2009
I have a mitsubishi 73 wd-73642 it had sound and I have picture but its dark and when I turn it off it just blinks yellow off and on what could be wrong
The dim picture is an indication that the Xenon lamp is at the end of life. Check the menu and settings to determine if the lamp needs replacing. Generally, they work well for 4000 hours then begin to get dimmer, slowly with time. Replacing the lamp is simple. You tube has videos that will show you how. The lamp should be less than $100 and can be ordered on line. I recommend you clean the DLP heat sink and the fans while you're at it to prevent overheating and eventual failure of the DLP chip. I had to replace the one in my WD-65835 Mitsubishi. Good luck.
Aug 26, 2016 | Mitsubishi Televison & Video
Mitsubishi WD-60C9 changing inputs on its own whats the cause of that?
HDMI auto is ON. Go to menu settings and turn OFF auto HDMI. That will stop the auto switching. Regards.
Aug 18, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Press and hold the POWER button on the control panel for 10 seconds to perform System Reset. TheTv`s "Listen to:"setting may be set to SAP (analog program from the ANT input).Plug an unused video Plug into the INPUT3 Y/VIDEO jack to activate Auto Input Sensing and make the audio device selectable in the Activity menu;InputMode may be selecting unrecognized AV audio input ; Wrong NetCommand settings SEE OnLine Owners Guide
Aug 28, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a mitsubishi 65"
its auto sensing optimal format from the input used u can try to go into your settings to force it full screen possibly with remote
Nov 17, 2010 | Mitsubishi WD-65738 DLP TV
My screen is stretched with a 1 and ahalf inch black space on the top and bottom
Most LCD monitors have a couple of control buttons at the top or on the side. Inside the menu, there should be an option called "Auto Adjust" which senses the input signal and resolution, and then shifts the monitor to match it. Have you tried to auto-adjust the screen? There may even be a button called "Auto" on the monitor.
May 13, 2009 | Computers & Internet
Wd-65835 not saving PerfectColor/Perfect Tint settings
I think you have to save it in the input selection, when you first turn on the set...
Mar 28, 2009 | Mitsubishi WD65835 65" HDTV
Mitsubishi 62" DLP Auto Sensing Gone???
yes - however, I recommend that u get it repaired professioinally so u don't get electrocuted
Feb 26, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Feb 10, 2009 | Mitsubishi WD-60735 Projection Television
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
