Question about Bosch HBL 5056 Electric Double Oven
We have a Bosch HBN 13N5.1B double oven. The manual refers to a "cleaning function" but nowhere does it tell you how to turn this on. Can you help please?
  • leanneoconno Mar 31, 2009
    Again I am looking for this self cleaning function referred to in the manual
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
SOURCE: Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Posted on Oct 02, 2007
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
Master_Tech
  • 770 Answers
SOURCE: Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Posted on Jan 27, 2008
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
Why wont fan turn off after use in oven bosch model hbn 13n5,1b
It should turn off after a while. The fan is actually the cooling of the case, it runs longer if I have used a higher temp setting. If it does not stop after app. 20 min something is broken.
Sep 03, 2014 | Bosch Ovens
Bosch HBN 91 Sticky Fan
Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bosch oven glass
http://www.bosch-home.co.uk/store/spareparts/search
Feb 20, 2013 | Bosch HBN 9061 / HBN 9021 Double Oven
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Easy off ate all enamel off interior of oven
First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
Feb 13, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
How do you programme Auto Start.
Here you go
http://safemanuals.com/user-guide-instructions-owner-manual/BOSCH/HBN5056AUC-_E
If this helps please leave feedback
Feb 12, 2009 | Bosch HBL 5056 Electric Double Oven
Bosch hbn s gb
oven element would need model and ENR No. to supply
Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Jan 20, 2008 | Bosch HBN 452 / HBN 456 Electric Double...
Bosch HBL 5056 Electric Double Oven Logo
65 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
