Question about HP ScanJet 3530C Flatbed Scanner
My hp3530c scanner stopped work when I'm connect it to power nothing happen I'm check dc supplier look good and supply 12v dc What is the next step to continue check I'm have checked internal fusses all good any sugestion is acceptable Thaks Aleks
    Scholar:
  • 91 Answers
This is a link to HP's website for your scanner:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01275876&jumpid=ot_recdoc/bps03297/en_us/c01275876/loc:4&custom_solutionid=rd_bps03297&lc=en&dlc=en&cc=us&lang=en&product=73497
Take a look. There is a lot of good information here. Please let me know if this has helped you. Thank you, Binary Bob
Posted on Dec 10, 2008
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
PSU Switching Adaptor for DVR NS801 stopped working
Don't waste your time, if possible take it back to your nearest Maplin with receipt and ask for a replacement or email ask for return item number and or request replacement or refund post back obtaining proof of posting.
Jan 28, 2013 | Kguard Home Security DVR Combo Kit 8...
I HAVE LOST THE POWER ADAPTER, CAN YOU SUPPLY A NEW ONE?
this one will work. http://www.buy.com/prod/belkin-12v-dc-power-adapter-20w-belkin-12v-dc-power-adapter-20w/q/loc/101/10296195.html
Mar 30, 2011 | Umax Astra 1220U Flatbed Scanner
My dash lights and my radio stop workin when i was installing a new radio, how can i fix this?
sounds like you have a problem with the power supply. Check the fuse. if ok, remove the new radio and check the power connection to the radio. if you cut into a wire harnis to find a hot 12v connection, you may have severed the dash 12v supply or knocked it loose . Take it slow and retrace your steps, but first check the fuse panel. You may have shorted out a wire without knowing it when attempting the install. lift the pos. lead on you battery the next time you play with 12v.
Sep 18, 2010 | 1994 Jeep Cherokee Country
Power coverter to scanner failure.which unit should i buy? present one 240v 50/60hz.0.4A. output 12v.dc.i.25A
I just found my Canon 5000F scanner to have a power supply outputting 3V DC instead of 12V DC. I replaced it with a 12V DC Power Supply from Tandy rated at 1.5 amps. I had the scans getting darker by the day and sometimes completely black. Now I have great scans again. Just test the voltage at the plug that supplies the scanner for a healthy 12V DC with a multimeter.
Jan 20, 2010 | Canon CanoScan 5000F Flatbed Scanner
Fuse and power supply look ok to the eye slight static sound on audio tiny flash intermitent inright corner on video, any clues? power diods check good ,nothing looks hot or burnt There is a second board...
Your power supply on the dc output should have the floowing DC voltages, 5v, 12v, and 24v. Just start probing the connectors of the power supply. 24v is needed for the backlights inverter board, 12v for sounds, 5v for logic board.
Dec 09, 2009 | Audiovox FPE3206 32 in. LCD Television
No power to my pioneer gm5300t
arcanum,
good day bro, from your Pioneer amp supply line do you also see a terminal marked as " System controller" ? did you also supply 12V DC to this terminal?
the standard power configuration for Pioneer Car amps would be:
12V Dc (+) supply / ( - ) supply ground / System Controller ( supplied by +12V DC)
12V ( + ) supply and The ( - ) supply ground is for stand by power, once you connect the supply through this terminal you will now have the stand by power but will not power on the unit even the LED power indicator.
System controller terminal, this should be supplied by ( + ) 12V line to power up the amp. this serves as the ON/OFF switch for the amp.
cheers,
mark
Jan 25, 2009 | Pioneer GM-5300T Car Audio Amplifier
Unsure about power supply
Don't know if you've got round this by now but the supply needs to be 12v 1A with the inner positive
Dec 21, 2008 | HP Scanjet 4400c Flatbed Scanner
HP 5470c - No power
I've done it, using an adjustable power supply all i needed was 12VDC - 2Amp, the power connector going to the scanner is a 4 pin mini-DIN male, so i've ripped of the cable from the original bad power module, cable has inside 2 wires one black one white and a shielding. Black and schielding are connected together and are going to the minus, the white one is going to +12V
guess what? .... my scanner is working again
Nov 25, 2007 | HP Scanjet 5470c Flatbed Scanner
New Power Cord Stopped Working
DO NOT use the HP power adapter that is 19V / 3.95A. That is too much power for the Scanjet, which is expecting 12V DC (and a much lower amperage). It's possible that hooking up this power adapter may further damage the electronics inside the scanner. If the second adapter has stopped working then it is possible that the internal circuit board has damage already and another adapter may not work. If you have access to a multimeter / voltmeter you could check for the 12V coming from the adapter. If you're getting the 12V, then the internal circuit board to the Scanjet is probably defective.
Nov 17, 2007 | HP Scanjet 4470c Flatbed Scanner
HP ScanJet 3530C Flatbed Scanner Logo
209 people viewed this question
Seeker5211
Seeker5211
