Question about GE 32GT740 32" TV
Can't program channels past 14
We can't get our tv to program channels past 14 and our cable thru channel 70
  • 51 Answers
Select cable as a source not broadcast its looking for UHF channels instead of cable up to say 100. go to setup select cable not antennea or broadcast. do a scan afterwards and ghave it find your channels
Posted on Dec 08, 2008
Everything from Channel 14 and up won't reset
If you have just an air antenna and your tv is set for cable and not air, you will not pickup any channels past 13.
Nov 20, 2011 | Televison & Video
I am using cable, no box, I want to program in the channels. The channels 1 thru 22 are already programmed but I want to add 23 thru 79 channels I can't figure it out.
The TV might have an auto programing function, which should tune in all available channels that are being delivered thru the cable/from the cable company.
Apr 15, 2010 | Samsung BN59-00455A Remote Control
Can't program the tv to go past channel 14 should the tv be on ant-A or cable
TV -if your using rabbit ears or anttena on the roof.
Cable -if you are a cable subscriber
Aug 04, 2009 | Televison & Video
Only goes up to Channel 19.
Go into the TV's setup screen and make sure its tuning mode is set for "cable" (may say "CATV"). I'm not familiar with this set so I don't know exactly what the screen will say, but there should be some reference to channel setup, TV setup, tuning band, etc. It's probably set on "AIR" now.
Normally, when set for off-air reception, the set works properly for channels 2 through 13, and 14 up don't tune properly. Since you're getting channels up to 19, there may in fact be some kind of tuner problem. If the TV is already set for cable tuning, you may have found why the former owner was freecycling it. But check that tuning mode.
Apr 06, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Programming Channels
Your TV is likely set for "AIR" tuning rather than "CABLE" mode. In this case channels above 13 don't tune correctly. The tuning mode is adjusted through the setup menu (it's been too long since I've seen one of these to remember exactly how the menu looks). Once you set the tuning mode for cable, all the available channels should come in properly.
But you've said you have satellite, so you should have a satellite receiver connected to your TV, and you'd be changing channels there rather than on the TV. Your TV would be staying on channel 3 or 4 (if using the satellite antenna output connection), or on the A/V input you have the satellite connected to (if using the direct A/V outputs). Am I missing something about your system?
Feb 18, 2009 | Mitsubishi WS-73905 73" Rear Projection...
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
Channels blocked
Hello to all, go to your TV menu and go to V-chip set up, then go thru and see that you don't have any channels blocked. If you do and you are watching a show with that rating, you will receive the "protected program message".
Have a great day!
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Second toshiba tv and they both do the same thing
Hi, It is possible that your Toshiba is set to receive aerial TV programs and not Cable TV programs. You need to go to the set-up menu (via remote) and go to the air/cable selection. Choose cable and then auto search/scan. This is a generic procedure and should work with your particular brand/model but the terms/names may just be a bit different. You may also consult the users manual for the exact procedure. Hope this give you an idea. Good luck and kind regards.
Aug 19, 2007 | Toshiba 30HF66 30" TV
Need help viewing all public television channels
Your TV is set for standard broadcast. You need to go to the set up menu and change from antenna/normal to cable mode. In standard broadcast mode you receive off the air programs 2-13 vhf and 14-83 uhf. In the cable you receive 2-13 and cable channels 14 -125 if the set is not too old. When cable channels first came out some sets would just cover 14- 36 or 14- 47 or 14-66 etc. The newer sets cover the now standard cable channels 14-125. Hope this helps you Stargazer
May 25, 2007 | Quasar SP-2725 27" TV
Remote not working correctly
It all depends on what and how the cable box is connected . Do you have an outside or inside antenna connected? If you have a cable box , why would you want to go to another station on your tv? Does the cable box have an rf output that connects to the tv through he antenna input on the back of the set? If so the tv should stay on a station to recive the stations thru the cable box. Didnt the cable tech explain how to use the system?? If you dont understand how to use the cable you should, for sure call the companey, and see if they can explain how they hooked up your sysytem as theres many many ways to do this. If you have the owners manual what im about to explain is in there too. On the tv remote theres a button called menu, press it once. Use the up and down arrows to scroon down and highlight the setup . press the ok or enter buttonpress the right language,then search for channels. When this is over then exit out of the menu, and try switching channels. If you still dont have any channels you gonna have to find out whats connected to your rf input as channels wont come in if theres not the right source connected. GOOD LUCK
Jun 18, 2006 | RCA G27303HP 27" TV
GE 32GT740 32" TV Logo
64 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
