Question about Classic Electronics DVHE210 System
Ntsc to pal
I accidently switched my classic dvhe210 dvd player to PAL, and now i can't see the screen to switch it back to ntsc
0 characters
1 Points
Why does it only play dvds in black and white
check color system settings pal to pal
TV PAL then DVD player has to be PAL
TV NTSC then DVD player needs to be NTSC
If mismatch in settings you may experience black and white
Dec 31, 2014 | JVC TH-A30 System
Pls tell us which tv set u have..
Dec 08, 2007 | Mintek DVA-8700 System
When you insert a dvd it says PAL DISK
PAL is the format of the dvd and there are two main formats for a dvd and they are PAL or NTSC. The NTSC format is mostly used for the United States, and the PAL format is used more in Europe and Asia. An older dvd player will have the format options in the setup menu for the dvd player, and from the setup menu on the tv screen the dvd player can be set to play the PAL dvd's. However if that is not the problem and the dvd player no longer can tell a PAL from a NTSC format then the dvd player either needs a serious lens cleaning or it has a malfunction. Also, the back of the cover for the dvd should say if it is PAL or NTSC.
Jun 16, 2010 | JVC TH-A9 System
Changing to NTCS to PAL. I've accidently changed
If you haven't solved this yet, just turn off the system. Press and hold the enter button on the front panel. While holding enter tap the store button a few times until you see "Video: PAL ###" and change this back to "Video: NTSC"
Apr 19, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
How do you change the DVD player mode from PAL to NTSC ?
I just found the way to change the setting from PAL to NTSC.
While the unit is turned off , press the EZ View button on the remote control. Press alternatively the select between the PAL or NTSC setting on the unit display. That's it.
Mar 17, 2009 | Home Theater Systems
Koss ks4102 pal/ntsc output
try to unplug the system for about 20min to see if it will reset the system
Dec 01, 2008 | Koss KS4102 System
Switching form PAL to NTSC
did you tried to switch back to factory settings? thanks
Apr 11, 2008 | Bose Lifestyle 38 System
No color when playing DVD
your player is set to the wrong format ie either ntsc if your in europe or pal if your in america, you need to go to the setup and make sure the dvd setup is for your region. pal in europe,ntsc in america..most dvd players automatically switch.but sometimes people change the settings without knowing.
Jul 01, 2007 | Bose Lifestyle 38 System
Playing burnt dvds in black and white
Cause: You are trying to play a DVD with NTSC-standard on a PAL-videodevice. Solution: switch your video-device to NTSC-standard or to "AUTO". Explanation: I had this "Black&White" problem after I played a DVD which I downloaded from Internet. My video-device (beamer) was set on PAL and gave black&white pictures, but when I switched it to "NTSC" the problem was solved. Apperently the Sony DAV-DZ100 switches automatically from PAL to NTSC when needed.
Nov 01, 2006 | Sony DAV-DZ100 System
Classic Electronics DVHE210 System Logo
16 people viewed this question
Top Classic Electronics Home Theater Systems Experts
Gyula Lacz
Are you a Classic Electronics Home Theater System Expert? Answer questions, earn points and help others
