Question about Kenmore 44042 Front Load Washer
Water filling tub
When my washer is not in use water fills the tub. So I've been having to turn the water off after every load. Then today I figured out that it's just the cold water that continues to run and fill the tub. I can leave the hot water turned on without a problem.
  • Debs
    Debs May 11, 2010
    this sounds like the water valve is faulty.
  • Kenmore Master
  • 3,463 Answers
You need a new cold inlet valve fitting.
Posted on Dec 08, 2008
3 Suggested Answers
  • 414 Answers
SOURCE: The washer fills and begins agitation, but
There is a pressure switch which stops the fill cycle, It is attached to the drum by a clear
tube. as the water comes up in the tank, pressure builds inside a cup that is molded on
the side of the tank, if the inlet to the pressure switch becomes plugged with lint, it
will cause this symptom. The switch is located behind the control panel. Unplug washer
and remove two philips head screws at bottom corners of the panel. It will usually hinge back. Inside is the float switch. Try removing the tube and blow into it, this will
clear the end, then see if it corrects the problem, if not then the switch has failed.
Hope this is of help to you.
Posted on Mar 10, 2011
  • 55 Answers
SOURCE: cold water won't stop filling the tub
The cold water valve is probably stuck open. It should open only when there is voltage across the valve. It could just be clogged inside. If you can remove it, you might be be able to take it apart and clean it. Just make a note of how parts fit together as you are taking it apart. Clean all parts with old toothbrush and reassamble. Before you reinstall, connect it to a garden hose outside. No water should come out when you turn the hose on. If it still fails, just buy a new valve.
Posted on Jan 25, 2008
The water, there was no water left in the tub of the washer, but the clothes were dripping wet; and the cycle was showing to be complete. I had to re-set the dial to the spin setting inorder to completely...
What has happened is that your water pump has gone out and it cannot pump the water out of the washers tub. This is a common issue and replacing the pump is not that hard assuming you have the time, effort, tools and energy.
Jan 23, 2011 | Kenmore 24962 Top Load Washer
Today was the first time this has ever happened, the washer filled with water as normal, I left on an errand expecting the load to be finished when I got home, nope. All the water was there in the tub,...
This is modst often caused by a defective lid safety switch. This switch will allow water to fill but no other washer action until the lid is down, it is the the #1 most common cause of your problem.
Jan 18, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Washer continues to fill and overflows
start to fill the washer,then turn it off,if water still keeps filling you have a bad inlet water valve,if it stops then check the water level water hose from the water level switch to the side of the outer tub-mike
Jan 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking from water output at top of washer
soundsas if you have a faulty, inlet water valve. your model is notshowing up on my part look ups, but definatly replace the valve( your water hoses are connected to it. in mean time make sure to turn off water inbetween loads
Dec 11, 2008 | Whirlpool GSC9455 Top Load Washer
Water Leak
Yes all you have to do is take off the front cover of the washer or the back cover, it it usually the front on top load washers. I believe your water pump may be cracked, but am not sure. What you need to do is remove the cover and start your washer and let it fill. Get a flashlight and pay close attention to where the water is leaking from. Then all you have to do is replace the part and your done. Any part dealing with water leaking will not be hard to change.
Sep 23, 2008 | Maytag MAV6200 Top Load Washer
Washer filled up with water when not turned on
It sounds like the water inlet valve assembly is letting a trickle of water thru when its not supposed to. It is located on the rear of the washer, it is the part the water hoses connect to. Make sure the power and water are turned off, then disconnect the water fill hoses. The valve is attached to a bracket, the valve will have 4 electrical selenoids on it and a hose leading further into the machine. Make a drawing of where the wires/colors were attached before you pull them off. The valve for that machine (MLG2000AWW or MLG2000AXW) usually costs about $45.00 to $55.00
Jan 19, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Kenmore 44042 Front Load Washer Logo
127 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
