Question about Canon i 470D InkJet Printer
Won't print I have a Canon I470D inkjet printer. The printer goes through all the moves, but no ink hits the paper. I have replaced both ink cartridges, replaced the print head, reloaded software, driver, powered both the printer and computer down and still does not print.I have a suspicion that the ribbon cable is bad, is this possible?
  • 3 more comments
  • Timothy Congdon Mar 16, 2007
    I know enough to change paper, I tried several different types. I do not see how paper will cause the printer not to work. This information was not what I expected and was disappointing.
    Congdonfam
  • squeenjor Jun 30, 2008
    I have replaced both ink cartridges, print head, uninstalled and reinstalled program and still no ink from my i470D.
    What gives?
  • jamsf Nov 08, 2008
    Canon i 470D printer has been working very well for some time. I have not used it about 6 months; went to print and printer goes through all the motions, but nothing prints. Re-seated print cartridges and can see on the bottomes that there is ink in them. Performed printer head maintenance and that did not help either. It seems like the printer head is no longer coming in contact with the paper. Adjusting lever on top of the mechanism that holds the printer cartridges did not help either.
    It bugs me when you don't touch something, it breaks! Any advice? JAF
  • tulipnn May 23, 2009
    I've got the same problem! The ink does not hit the paper though I've replaced both ink cartridges with new ones. Could someone please advise? I've been using it regularly and the last time I printed something out was last week.
    Thanks - Nanz
  • Anonymous Mar 19, 2014
    lost my manuel and don't know how to hook up to dell laptop computer. don't know where cable plugs go in computer or printer plus where ink goes.
    Problem Solver:
  • 17 Answers
Not normally,try new paper. chook.
Posted on Mar 14, 2007
My Canon Pixma MX882 is not printing though lots of ink. Paper goes through when I press print on my PC but nothing is printed
Print a test sheet to see if the printer is OK. If tthe sheet prints fine has this printer worked on this computer before? Did you change anything or update anything? You may have the wrong driver installed or the cable could be defective if it has worked before.
Feb 02, 2015 | Canon PIXMA Office Equipment & Supplies
Code 6A00 is comming up whenever I try to print. kindly advise me how to solve
Hello and Welcome to FixYa!
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon PIXMA iP6700D InkJet Photo Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
May 10, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
I got error 6A00. model mp830
Hello i hope u 'll be fine.... thanks for using fixya.
Canon PIXMA MP830 All-In-One InkJet Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Dec 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
The printhead moves and it sounds loke it is printing but the paper is blank?
A few possibilities:
1. out of ink -- replace the ink-cartridge
2. clogged ink-jets -- run the "print-head-cleaning" utility.
3. messed-up electronics inside the printer -- buy a new printer.
Aug 28, 2010 | Canon i9900 InkJet Photo Printer
Error 6400 ink cartridges wont track accross
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Feb 07, 2010 | Office Equipment & Supplies
Canon BJC 4400 won't put ink on the paper
You need a new printhead, BC-21E, they wear out and plug with ink and the only repair is to replace the printhead.
Sep 16, 2009 | Canon BJC 4400 InkJet Printer
Service error 6A00
It looks like the print carriage was stuck. Turn on off the printer, manually move the ink cartridge back and forth a few times, look underneath for dirt or small piece of paper (usually happens when you have jammed paper) or use a blower to clean any foreign objects.
Apr 27, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i470D Waste Ink Tank is Completely Full. How Do I Clean It?
There is a cleaning solution sold on E-bay for Cannon i470D print heads.
Or you can try a little ammonia. I used a cap full of ammonia in each side of the print head where the ink tanks go.
Put the print head in a can and let it set in the ammonia for 5-15 minutes then blot dry with paper towels and let stand until dry.
Then run the maint routines for the print head found under properties/maintance.
Dec 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon I470D not printing
may be your cartridge is empty or try out head cleaning to run the flow of ink into the new head.wish u success!
Jun 04, 2008 | Office Equipment & Supplies
Canon i 470D InkJet Printer Logo
417 people viewed this question
Clive
Clive
old marine
old marine
