Question about Braun FlavorSelect KF 180 Coffee Maker
Braun Coffeemaker Programming
Braun Coffeemaker Instructions
I just purchased a used Braun Flavor Select KF180 and cannot figure out how to program it for automatic brewing. Can you help?
  • Paul Hitchings
    Paul Hitchings May 11, 2010
    what buttons does the machine have?
    Problem Solver:
  • 5 Answers
To prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Posted on Jun 20, 2010
Hold down this automatic button till it starts blinking then change to desired time.
Posted on Jan 17, 2009
Braun 3105 coffeemaker turns on, but will not start brewing, but if I slap the sides of the base by jarring it, it kicks off and brews just fine. Why is it not starting to ciphon the water on its own?
I am sure you have a reset button. If the coffee maker is still fairly new you can take it back to the store one one that sells this brand and might just replace it. What you have is a short.
Apr 06, 2017 | Braun Coffee Makers & Espresso Machines
How can I program my remote?
Remote for ? door unlock / lock , remote start , garage door opener .
If the door lock / unlock , panic alarm ,remote start . You can't dealer only . Need a factory scan tool .
Transmitter Programming
Important: Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed.
Invalidate All
This procedure will erase all keyless entry transmitters from memory.
Install a scan tool.
Turn ON the ignition with the engine OFF.
With the scan tool, select Body.
Select Remote Control Door Lock Receiver (RCDLR).
Select Module Setup.
Select Program Key Fobs.
Select Invalidate All Fobs.
Follow the scan tool on screen instructions.
Transmitter Slot Programming
Transmitter slot programming allows a single transmitter to be programmed into a specific slot without affecting any of the other programmed transmitters. By using slot programming, the transmitter originally programmed to a specific slot is erased and the new transmitter learned in its placed.
Select the key fob desired to be programmed.
Remove the scan tool.
Exit the vehicle. Operate all functions on transmitters to verify correct system operation.
Jun 05, 2015 | 2007 Buick LaCrosse CXL Sedan
How do i get another cls1100 on the same freq and code #?
Not certain if you are referring to purchasing another radio or programming an existing radio. So we will answer both:
1) If programming another CLS1110 to match your existing radio, First try it straight out of the box and fully charged. Many people use the default factory programming. If that does not work follow the simple instructions on page 26 in the user guide. Here is a link: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf There are also cloning instructions on page 32.
2) If you are talking from the perspective of purchasing a new radio, all CLS1110 radios operate on the same frequencies/PL codes. (Unless you have a foreign model purchased in another country, then it is iffy) Simply purchase your new radio and follow the programming instructions above.
Best regards.
Aug 04, 2011 | Motorola CLS 1110 (1 Channel) 2-Way Radio
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
How do I program my coffee pot to start brewing at a certain time...I lost the manual and can't figure it out...
Go to this website:
http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Enter your model number and click on search. If the search function does not produce a Use & Care Manual for your model try manually searching the list o ther page below for a similar model.
Follow the programming instruction in your Use & Care Guide.
Mar 08, 2011 | Black & Decker 12-Cup Programmable...
Any one know how to set the shut off timer on the KF180 Braun coffee maker
Hold down on/off button until it blinks. Display should read 3:59. Adjust with "h" & "m" buttons to set auto shut off duration.
Feb 25, 2011 | Braun FlavorSelect KF 180 Coffee Maker
Can you tell me where I can look at a Braun 3107 instruction manual online? Thanks, Bill Kossler
The manual is available from the Braun support site: http://www.service.braun.com/product/search.asp?rg=NA&c=US&l=GB&typ=ui&frmTyp=subgrp&sgrp=subgrp&grp=HH02%3C'%3E&s=3107+&subgrp=Tassimo . (The last manual in the list is the North American version.)
I hope this helps.
(alternatively go to braun.com, select your region and then the link for User's Manuals. Select Coffeemaker and Tassimo in the drop down menus on the right.)
Nov 06, 2010 | Braun Tassimo Espresso Machine/Coffee...
Coffeemaker is falling apart
Unless the product is still under warranty, I would look for a new different brand. I have personally used a 'Mr Coffee' unit with similar features and with the exception of periodic cleaning with water/white vinegar solution, it has worked fairly well. The pot dribbles a little if not carefully poured and if the basket is not fully seated, coffee runs all over. Everyone has had a turn at dealing with poorly made/designed products that fail to meet expectations. Better luck next time!
Mar 01, 2010 | Braun KF 590 10-Cup Coffee Maker
Braun FlavorSelect KF 180 Coffee Maker Logo
668 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
