Question about Epson Stylus C84 InkJet Printer
Black not printing about every 3rd line
I have an Epson DX4000. It copies fine but when printing from the net colour is fine but black has lines missing. Have done the nozzle check, head cleaning and realignment. Still doing it. Any ideas what else I can try. I have a 5 year old Epson Stylus C84 and its doing the same thing (not printing every 3rd line). I just installed a new black ink cartridge and have done several nozzle cleans and alignments with no improvement...HELP!
  • 1 more comment
  • Fulks6 Jan 29, 2009
    My Espon Stylus CX600, had a paper jam and now every third line barely prints. How do you fix this problem?
    I meant CX6000, if that matters
  • tinkerbel487 Mar 05, 2009
    I have the same problem. I have done all the checks and cleaning and the print is still missing some print, you can see the print at the top but it is missing from the bottom of that row. Another row is blank other rows are perfect. does anyone know what is causing this. I have just put a new black ink in the printer and ran it a few times to try and get it started. Now I don't want to worry you, as I am myself, but this happened to my cannon printer, I tried to fix it over a period of days nothing worked, what happened next the printer stopped working and I had to buy a new printer, this is the Epson dx4000 printer doing the same thing. I have called it the Epson dx4000 as this is what windows set it as. the printer is a dx4450 could anyone tell me why this has happened. I would like to thank anyone now for your help. Tink
  • 353 Answers
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Posted on Feb 01, 2009
After about week of my Epson CX6000 printer being unplugged, my roommate lifted up the ink then put it back down and now my printer works again, I'm assuming that fixed it because now it works again.
Posted on Feb 03, 2009
My epson printer is printing the black from all the other colors, and ignoring the black ink cartridge
If you are printing "graphic" images ie photos, pdf's, fancy type-faces, lines or grayscale - your print is defined as colour and will be printed using colour shaded with black.
Apr 29, 2016 | Epson Artisan 810 AllInOne InkJet Printer
Printer only prints top and bottom lines on page
All web based documents, especially bank statements, require a COLOUR cartridge, so if your cartridge is empty, it will print blank pages. Although the font may look black... it is normally NOT. Altentaively you may also need to instruct your printer to print "background images".
Jul 08, 2012 | HP Deskjet D1000 J110a Printer Catalog...
Black solid line on the right hand of page when
Hi, remove the black drum and clean the corona wites and drum GENTLY with a LINT FREE CLOTH. If there uis no change in the print quality you may need to replace the black drum. Hope this helps
Feb 18, 2010 | Epson Aculaser C1100 Printer
My Epson is printing fine lines of different colours across and over the images that I am printing, if i am printing black the lines are blue, if in colour the lines are magenta or blue in different parts...
Check out this link for Stylus drivers for your printer. What I have found is that you can always go down with printer model for updating drivers but not up. Just copy and paste into your browser.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14387&prodoid=28907797&infoType=Downloads&platform=All
Let me know if this helps, and if I can help you with anything else.
JimmyC
Oct 02, 2009 | Epson Stylus Photo 1290 InkJet Printer
Inks
Hi, Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. Unless you have selected "print in black & white only" your printer will "mix" the coloured inks with the black, also check the printer options to ensure you are not using the photographic quality as this will use inks very rapidly. You need to consider a couple of things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Jul 09, 2009 | Epson Office Equipment & Supplies
http://www.hp.com/#Support this link could solve your problem. also make sure you are using good quality ink for your printers. I use to have many problems with my printers and then i started purchasing my ink from www.yahootoners.com , you could not find a better price quality product anywhere else. trust me its worth it.
Nov 23, 2008 | Epson Stylus C86 InkJet Printer
Epson DX4000 printer
Hi..
Try this. Removed the color cartridge. Open the printer settings under Quality and check the box that says print in "greyscale" or "black and white.
This will rule out and color cart problem and also change the printer settings. You will have to change this back to print in Color,
Hope this helped........
Squipps
Feb 06, 2008 | Office Equipment & Supplies
Blue lines all over the printing
Did u clean the print nozzle's as well? If that does not solve your problem, you should try and replace the cartridge. (Colour in case of blue lines and black in case of black lines)
Jan 22, 2007 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
1,384 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
