Question about Honeywell Home Security
PIR Intruder alarm magnetic contact
Honeywell Accenta Mini Gen4 intruder panel with LCD keypad
brought an intruder alarm a G4 from screwfix, want to fit flush magnetic contact a Honeywell EMPS-75W the magnetic contact has 5 terminal 3 brass 2 silver, can anyone help me on how you wire them into the system,
please bear in mind this is my first alarm that I've done.
even better if anyone has a complete wiring diagram
Steve from Kent England
  • bowdi Dec 14, 2008
Its a long time since i worked on these but its quite easy you want the 2 terminals that make a circuit when the magnet is placed by the switch and breaks the circuit when the magnet is removed.hope this helps
les from new zealand (ex uk)
Posted on Dec 14, 2008
Hi Bowdi,
Please find the below the information on the contacts.
You will fine two silver screws - This is your Alarm pair and this will go back to the alarm zone on the panel PCB.
The three other brass screws are just junction screws so you can join the cables to go to other doors.
You will need to join the black and blue together to make the tamper circuit.
Regards will
Posted on Sep 06, 2009
What is needed to put a self contained siren in a wireless honeywell lynx plus keypad
5100 or 5200 is here
Jun 14, 2014 | Siren Wireless Security System House...
You have most likely "bought a duffer" I have 30 years experience with alarms.
!. Remove the internal battery, power down the panel.
2. leave "dead" for 10 minutes.
3. reinstate the power, Mains first then refit battery (Make sure terminals are correct for each wire)
4. Retest.
If the above does not work give Lynteck a call on
  • 01282 717 490
  • email
Mar 05, 2017 | Home Security
Brand new door contacts on my wired alarm system not working properly
1. Make sure you have a (EOL) resitor on the curcuit, it should be at the switch, but you can cheet and have it at the panel, but if your wire would ever get damaged you would not know about it 2. If you had to hammer in the switch it could have damaged the switch to a closed state and wont open when the door opens, the switch should just be pushed in not hammered 3.If the switch is installed to close to a magnet wheather stripe, that will hold the switch close 4. If it is a steel door and steel frame, and the switch is a surface switch with screw terminals, you could have some stray wires shorting to the steel frame 5. make sure your magnet is lined up with the switch
Jan 05, 2013 | Honeywell Home Security
I have an accenta 6 burgler alarm, i recently had a ceiling replastered and the guy that did it moved the sensor and dislodged the wiring , and didnt say anything and iwasnt there when he did the job.When...
Hi, it is always best to disconect from mains before working.
can u see what fuse has gone?
it should be fine leaving battery in or your alarm might go off cause bell boxes have there own battery backup, just make sure you sort out shorted wires first and replace with same fuse.
maplins ok if local but not the cheapest
Oct 10, 2009 | Honeywell Home Security
How do you set logic six alarm keys from alarm keypad
You should go to the this link and follow the process.
If it doesn't work then let me know.
Sep 14, 2009 | Computers & Internet
Fuse box
The main fuse is under the panel on the right side behind the forks and the rest of the fuses are in the crank case under the cover...where you fill the oil.
Nov 10, 2008 | 2004 Suzuki VL 1500 Intruder LC
Home Security Logo
770 people viewed this question
Top Honeywell Home Security Experts
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
