Question about Dyna-Glo Heating & Cooling
Error code 1
Stored heater since last march went to fire up the heater and it gives code e 1 missplaced manuel do not know where to begin
  • 57 Answers
Try googling for a manual. You may be able to find one online at Homedepot's site or Lowe's if they carry the heater.
Posted on Dec 09, 2008
Is there a required update for my Kindle fire?
Patricia, Yes. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon update your old Kindles or youll be cut off from the store
Mar 22, 2016 | Amazon Kindle Fire HD
I turn on the heater and get error code R=9 and then shuts off....what do I do?
R9 is not an error code, but a software revision code.
Here is what you should do.
Take off the front panel underneath the circuit board.
Turn the heater on, if it doesn't Fire and gives no error code you need to look at the back of he circuit board and see what red lights are on. If you find one on there will be letters next to it to point you in the right direction of the issue. Example h1 or h2 would mean high limit 1 or 2.
If you don't have space to look by taking off the front panel only then you would have to take all panels off and get the top loose so you can lift it carefully to access the back of the circuit board.
Once you've done this let me know what you find and I may be able to further assist
Jan 15, 2015 | Pentair Master Temp 400K BTU Natural Gas...
How can i update my wii without error code 32007?
Personally, I think the Wii support is giving up. It is outdated technolagy.
Jul 13, 2014 | Nintendo Wii Console
I have a 1996 GMC Jimmy that was iddling very rough and code said cylinder 2 misfire check engine light was on solid. Replaced all plugs, wires, cap and fuel filter 1st of March 2013. It ran better for a...
Lets start at the beginning. Did anyone check fuel pressure before and after replacing the pump ?
Has anyone checked the fuel pressure regulator and the injector spider ? The 4.3w engine uses a spider with one injector that supplies all 6 cylinders. And it runs at 65psi or more.
Aug 05, 2013 | 1996 GMC Jimmy
Model EG5000, one year old;last fire up in March, now it doesn't start. Has fresh gasoline
i'm sure you primed it - or go get a can of ether spray in carburetor
Oct 28, 2012 | Honda EG5000 Generator
Replacing heater coil on 1994 honda accord
Replacing the heater CORE ? Drain the cooling system disconnect the heater hoses under the hood at the fire wall then remove the glove box inside the car . then remove the heater box as a whole unit . Take to your work bench now seperate the the unit and remove the heater core.install the new core and reinstall every thing that you took out in reverse order . This is a 5 hour job and if you are not a technician i would not recommend trying this with out buying the work shop manuel for you to follow step by step . You can buy one online at a book store or a parts store . The Chilton manuels are the best in my opinion . Good Luck
Aug 05, 2012 | 1994 Honda Accord
Heating & Cooling Logo
162 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
