Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
KDF60WF655 Popping, Cracking, Squeaking sounds?
I've had my KDF60WF655 for two years now and it has been excellent in every way. Recently however it seems the TV has started to settle and it makes popping sounds when either on or off. These popping sounds are not audio related, they are similar to what you would hear if you pushed or pulled on the TV from different sides. The sound can be reproduced most accurately by pulling forward on the top of the screen. The sounds are clearly being made by the plastic TV housing or structural plastic inside the TV and there are no physical signs of any problems. Have any other KDF60WF655 owners experienced these same sounds? Thanks in advance - Aaron
  • 103 Answers
The outer screen case screws need to be tightened.
Posted on Mar 06, 2007
Took a right turn, made a loud pop sound, now won't stop making a popping sound. Not as loud as the first pop sound. What could it be?
Not enough information to answer. Need manufacturer, year, model, and engine size in order to answer the question.
Oct 22, 2015 | Cars & Trucks
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
What could cause loud popping sounds?
The sounds you are hearing is the defrosted water, from auto defrosting, running onto the hot compressor. This evaporates the defrosted water. This is quite normal.
Mar 23, 2014 | Samsung RF260BEAEWW
Popping and squeaking sound
The popping sound could be UV joints. But hard to tell if one cannot hear them. Worse case scenario, transmission going. The squeaking sound is probably your struts. The upper strut bearings are probably worn, and that could mean the struts are worn too. Depends on the mileage on your vehicle. The springs twist when under stress and this is what the upper bearing is for. In good shape, it would not make any sounds.
Mar 05, 2014 | 2004 Saturn ION
Our Kenmore Elite 45992 is making a loud squeaking sound when it spins clothes. We've checked the belt and shocks and they are okay. Any ideas?
Had same problem mine was the yoke thatheld inner drum tobearing was broken. Lucky it was covered by Sears warrenty. Over $1,000 to repair without warrenty..
Sep 30, 2012 | Kenmore Elite Washing Machines
Spond keeps popping & cracking & screeching, finally no sound.
Check and replace damaged component/s in the audio output section circuit.
Aug 18, 2012 | Polaroid FLM-323B Television
When pedaling starts off making squeaking sound but now it is very loud with cracking and popping.
Pedal or bottom bracket bearings need a look. The web has many resources for identifying noises on a bike. Just search for a few key words. For example "bicycle pedal loud cracking and popping"
One resource...
http://www.parktool.com/blog/repair-help/trouble-shooting-a-creaky-or-noisy-drive-train
Happy hunting.
Aug 18, 2011 | Cycling
One speaker making a popping sound
try switching the popping speaker to the other side and see if it still pops if it does then you have probably damaged the driver in the speaker if it doesnt pop then the problem probably is in the receiver
May 27, 2009 | Samsung Audio Players & Recorders
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Loud Cracking/Popping Sound
Any other symptoms? You may be just hearing the occasional sound of static being bled off, or, if the set is not working properly, the sound of the high voltage section trying to compensate...accordianman
Feb 25, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
126 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
