Question about Kodak Cameras
I need a a/v cable for my kodak camera dx4530. i have lost my original. the cable comes with 3 coloured ends. red white and yellow
  • wotheress Dec 08, 2008
    i have already been there, spoken with live chat and it's discontinued.
    thanks for your help, keep up the good work
  • 903 Answers
Http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=9/35&pq-locale=en_GB
try here for accessories for kodak cameras
I hope this helps
Posted on Dec 08, 2008
Does the Magic Sing ET19KV require a special "3.5mm to 3 RCA" cable? How to get it to work with aftermarket "3.5mm to 3 RCA" cable? "3.5mm to video only" works.
Hi
firstly check that the 3.5mm plug has the same number of contacts as the original there should be 4 segments
The three rca plugs are coloured red white and yellow
white is left audio,red is right audio and yellow is video
usually composite video.
some tv,s have an rca input some have two
and some have rca outputs
the sockets on the tv are also coloured to match the plugs
please check that the plugs are inserted into the correct
coloured input sockets
I would plug in the 3.5mm plug then the yellow untill i get video,once i have video i would connect the red plug untill i have sound,same with the white
Dec 03, 2017 | Televison & Video
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Office Equipment & Supplies
I want to order a user's manual for a Kodak Easy Share DX4530 for this camera and also a booklet of accessories. Please send address and cost to my email address. thank you. **Please do not use, rent...
user guide:
http://support.en.kodak.com/app/answers/detail/a_id/18504/kw/dx4530
accessories:
http://support.en.kodak.com/app/answers/detail/a_id/18379/kw/dx4530
Nov 06, 2010 | Kodak EasyShare DX4530 Digital Camera
I have a vizio tv set and want to ad a dvd player. how do i do it
get an a/v cable 3 heads yellow for visuals and red and white for stereo sound plug each end of the jack into the right colours of the tv and dvd sets i.e yellow to yellow and white to white then connect power and select video or dvd channel on tv and enjoy!
Jul 29, 2010 | Computers & Internet
Manual for samsung es65 camera I would like to view my pictures on my samsung TV I was told I could do this direct from the camera to the TV just by using the a/v cable Is this correct and if so what ports...
You can download a user manual from here:-
http://downloadcenter.samsung.com/content/UM/201002/20100202195655453/ES65_ES67_English.pdf
You should have a AV cable with the camera, that has 1 round plug at one end and 3 round plugs at the other.
The single end plugs into your camera, there is a socket on the side marked AV. The three plugs at the other end go intot the TV.
They are colour coded (White - audio left, Yellow - Video and Red - Audio right) you need to find three sockets on your TV which match. Once connected and a slide show running on your camera, select one of the AV tv channels on your tv remote control.
If there isn't the 3 colour coded sockets on your TV, there probably is a couple of SCART connectors on the back (Big black socket with about 20 holes) You can buy adaptors, from electrical stores, which convert your AV cable out to a scart. Its just a box with the 3 coloured inputs and a scart output.
Jul 03, 2010 | Samsung Cameras
I have a Kodak dx4530. Recently, when I push the
The camera is not recommending the picture, It could be overexposed, shaky or taken in the wrong SCN.
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak EasyShare DX4530 Digital Camera
No colour when watching dvds ok for everything elese
You will have to make sure you are connecting them with the red and white cables on audio and the yellow on video at both ends, as both your dvd and tv have low def and hi def cabling options.
That means Red and White to Audio at each end and Yellow to video at both ends. If you connect the yellow cable to one of the other three connectors at iether end you will only get black and white as they are meant for a different type of connection.
To get the maximum quality out of your sets you may want to purchase a set of Hi-Definition Component cables which will give you a set of five cables, still red and white for audio but now red, green, blue for video.
Hope this heps a bit more,
Chris
Apr 30, 2009 | Panasonic DMR-ES35VS
Samsung 880x digital zoom scl906 need cord for tv
The cable that goes from the camcorder to the TV or VCR is a simple one to replace. It's got a standard 3.5mm stereo headphone jack at one end and RCA's at the other. So all you need is a cord that is designed to let you play an MP3 player through a home stereo, and Radio Shack sells these, as does Wal Mart. The only thing is that one cable will be red and one white, whereas the original had one yellow and one white. Just plug the red plug into the yellow video-in jack on your TV or VCR.
Apr 26, 2008 | Samsung SC-L906 Camcorder
Cameras Logo
23 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
