Question about Hotpoint Washing Machines
Washer shakes and rattles when using regular cycle.
The washer was moved when a new floor was put down. Once it was moved back into the laundry room and re-setup, everytime I use the normal cycle, the machine shakes and makes a huge racket. If I change the cyle to perm. press or more delicate, the machine works like a charm. Any suggestions on how to fix this problem?
  • dona_rob Dec 11, 2008
    Thank you!!!
    I just had a chance to use the washer today after my husband really did the tug and shake suggestion. It's back to being my ol' washer again. I've now added Fixya to my "favorites" for future.
  • 51 Answers
Just a long shot but open it up and grab the edge of the tub and give it a good tug and a shake in an effort to get the tub (empty) to settle in properly on the suspension springs inside.
Posted on Dec 08, 2008
Recently moved our laundry room from 1st to 2nd floor, not realizing that front load washers are not good for the 2nd floor...
look the really heavy duty floor pads used in horse stables very dense and thicker than anti vib because even it restacked extra weight wont stop the vibration
Jul 27, 2016 | LG Washing Machines
LG front loading washer: recently moved to a new house and laundry room is on the 2nd floor. Re-installed the shipping bolts in the back of the washer that secures the drum prior to moving the washer. But...
Make sure machine is level and all four leveling legs are solidly touching floor at the same time. Make sure leveling leg locking nuts are screwed up to lock legs in place. Check floor for firmness. (try bouncing up and down in front of washer to see if the floor has excessive give.) You may need to re-inforce floor. Wash larger loads. On bulky items, use a lower spin speed. You can re-spin at a higher speed after cycle is complete if you want them spun out better. (some models have a pump and spin only setting, on others, just turn on the power and then only touch the spin speed button to select a 14 minute pump and spin only cycle, then touch the start button.) The only other thing is that the new LG washers use a balance ring now, which makes the machine perform much smoother. (I know because I gave my old LG to my son and replaced it with the newer model, which now runs much quieter, in the exact same location as the old one.)
Jan 13, 2010 | Washing Machines
Kenmore elite steam front load washer
take the shipping materail out,,remoce the 4 bolts on back of machine,,the washer should of came with a little wrench...after removing shipping bolts put the 4 white sluggs or vcaps in hole ,,pull bolts with rubber or plastic grommet..onthejob
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Vibrates and moves during spin cycle
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Dec 27, 2008 | Admiral AW22 Top Load Washer
Washer Shaking Violently on Spin Cycle
Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength for leaking issues Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Nov 24, 2008 | Maytag PAV2300 Top Load Washer
Shaking during rinse
Nov 12, 2008 | Whirlpool Washing Machines
Excessive vibrations
I have ordered KE shake away pads. I'll have to see how they work.
Jul 01, 2008 | GE Washing Machines
Amana NAV8800AWW making noise while running and spining. It used to shake the floor while spining. But lately machine is making noise but not as shaky as it use to be. Thanks for your help.
Spin Shake is usually contributed to a weak floor support condition. Also, carpeting under the leveling legs can cause a "spongey" effect, which can produce the shakes. Prolonged shaking can cause parts to loosen and make noise.Firstly, we must determine what loosened up from all the shaking.
Remove the front panel by removing the 2-5/16" screws located at the bottom front. Pull out at the bottom to release the top retainer clips, and set aside.
Warning! Never reach inside the machine while it is in operation!
Investigate the cause of the noise by setting the washer to spin, and turn on. Inspect all moving parts for possible wear or breakage. Next, stop the machine and inspect for loose or worn suspension parts, nuts, bolts, struts, hoses banging the cabinet, etc. A protective motor cover can cause noise, or a belt slapping the base mount. Once you have conquered your noise issue, then we will have to eliminate the shakes, provided, what you repaired wasn't the cause...and usually isn't.
Carpeting under the leveling legs should be removed or cut away.
If other items in and around the laundry room shake, then you will need to add support to your floor joists. Shim the floor from under the house while the washer is spinning for best results.
Your installation instruction manual should tell how level the washer properly, after you have added support to your floor.
Good Luck! Post me back if can be of more assistance.
Dave E. (Illeagle)
May 20, 2008 | Amana NAV8800E Top Load Washer
Washing Machines Logo
117 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
