Question about Refrigerators
''GE tfx28ppcb fridge has water puddle usually on right side
Leaks faster when water dispenser active, but can not locate source through rear when plate removed at water conection to unit.
would like to remove frame around dispenser in front of freezer door. no screws visable from outside. is the frame just pried off or are there screws inside freezer door. Do not see any signs of leaking water inside refrigerator.
I had the same problem, I found that the plastic tubing feeding the water despendor and icemaker was run right along the comperssor, over tiem the from exposure to the heat the tubing had become brittle and cracked.  the black tube shiled had to slid up to expose the cracked tube. A  new tub installed and splice to existing dispensor feed line fixed probelm.
Posted on Apr 06, 2009
My water dispenser was not working. Tried the defrost trick and still no water. Noticed water under the refrigerator.
The Dispenser supply usually flows through the bottom, inside toward the back to cool the water. If the puddle is near the back. refrigerator section it's probably this water cooling arrangement. Usually. a number of the tubing loops near the back bottom edge. Connections here or tubing itself may leak. It may also be an undetected leak from the Filter housing or the filter is not properly seated or possible filter housing connections. I have had good success with paper towel detection method. Wrap
or paste, tape towel to suspect leak locations. They will soon appear and point to the apparent leak.
Apr 01, 2015 | Refrigerators
I push the water dispenser and no water comes out but comes out at the bottom?
The hose to the water dispenser up front cannot be connected and it is spilling the water onto the floor when the solenoid is activated.
Jul 13, 2017 | LG LSC26905TT Side by Side Refrigerator
Puddle in front of TFX24CRS
If there is ice on the floor of the freezer, you have a blocked defrost drain. If no ice there, you are getting water from the water / ice dispenser, possibly down the back side of the door panel.
Seal the seams around the water catching recess at your dispenser with a bit of clear silicone. (corners and along the front edge seam with the front door panel.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
GE GSS22JFMC when I press the water button it leaks
That's where the water line runs to get to the dispenser. You may have to remove the cardboard backing to see it. The line runs from the water inlet valve. That's where the supply line from the house connects to the fridge. One line goes up to the ice maker and the other goes over to the fridge side where it goes inside the fridge behind the crisper to a reservoir where the water is chilled before it goes to the dispenser. Look for the water coming out when someone else tries the dispenser. Look for a fitting that has come loose.
Oct 02, 2009 | Refrigerators
Water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Nov 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
309 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
