Tv turns on but there is just a horizontal line about 5mm thick ,the sound is ok
    Genius:
  • 1,550 Answers
Maybe the vertical IC are damaged you need to replace him
Posted on Dec 08, 2008
When tv is powered on tv only displaying channel number and sound -no raster. using video mode displays are ok. sound is also ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 06, 2014 | Sharp Televison & Video
Hey..i have a thick white line horizontally across the middle of the screen..how can I fix this? TV is a 50
Hello
You haven't given the exact brand name and model number to your TV here for reference. Anyway, if it is an LCD TV, check its CCFL tubes behind the LCD panel for uniform brightness. There will be more that 12 numbers of them. All of them must emit light of same intensity. OK.
Feb 15, 2012 | Panasonic Televison & Video
Screen is black wiht a single 1/8 thick horizontal line across entire screen. Sound is ok. Other TVs are working.
cold solder in vertical ic and check caps around to..if you see resin around any cap, change.
Apr 22, 2010 | Toshiba CF32H40 32" TV
4 inch horizontal black bar across my 42 inch dell plasma. tv doesnt shut off and sound ok
The thick bar you are seeing could be a couple of things - either your HDMI or any other wire your connecting has been run too close to electrical lines, or your cable incoming needs to be grounded and/or filtered. It could also be a defect in the TV.
Sometimes it will just go away.... Its hard to tell without actually looking at your setup and television.
Feb 25, 2010 | Dell W4201C 42 in. Plasma HDTV
Epson stylus photo R2400
I had this trouble, went through cleaning & realignment, then various print options. What i found was that dark colours had faint dark horizontal lines 5mm apart when printing on Photo in the epson driver. Changing it to Best Photo solved it.
Jul 31, 2008 | Epson Stylus Photo R2400 InkJet Printer
Toshiba 40pw8db with colored lines horizontally
there are some boards in the tv that plug in (push down) have the power off and unplugged have a look around, and see if any boards have come loose, stay away from any thick red wires (EHT) DO NOT PULL At the Gray Rubber Caps that go to each gun (tube) RED GREEN Blue, this can carry a heavey charge even if the tv is off and has been for days, regards mark
Mar 15, 2008 | Toshiba 40H80 40" Rear Projection...
Syncmaster 245B Monitor Shivering horizontal lines
Which type of video connector are you using? VGA or DVI?
If you are using VGA, the horizontal line could be due to interference, like from an electric motor (fan) near the video cable.
Other thing to try is to change the refresh rate. In Windows XP: Control panel --> Display Properties --> Settings tab --> Advanced button --> Monitor tab --> Screen refresh rate. The default ot 60Hz for LCD monitors. Bump it up to 75Hz. That could give a clue to the problem or maybe even fix it.
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
