Question about AT&T Blackberry Curve 8300 Smartphone
Where is the location of the reset button
My daughter wants to put her sim card in my bb curve but it wont open! i thought i have to reset the phone and then try but cant locate the reset button.
what does one do in this situation and where is that button ?
    Guru:
  • 1,049 Answers
First, you do not need to reset the phone to install the sim card. You open the back, remove the battery, and the sim card installs underneath. There is a small lever you shift before it will insert properly and it should go in easily without resistance if this is switched correctly.
Secondly, if you need to do a hard reset for some reason you can do it by going to options / security options / general settings / menu / wipe handheld / "blackberry"...but this will take it back to being a clean out of the box black berry.
Posted on Dec 08, 2008
How can i find out the passcode for a blackberry 831o?
Posted on Dec 09, 2008
Invalid SIM card
If the Blackberry Phone says Invalid Sim message on the display.It is locked to Network.You need to unlock it to use other network sim card.Visit the site Wickedunlock.com
get the unlock code and unlock it from network lock.Then use any GSM network sim card in it.
Dec 01, 2012 | Research In Motion Rim Blackberry 9300...
In need of master security code or puk code for blackberry curve 8310
u need to borrow or use someone elses phone n call t mobils cs help line n tell them u accidentally locked ur sim card n need the puk code, they will tell u wht to do from there n give u the master code as well.
Sep 06, 2012 | AT&T BlackBerry Curve 8310 Cell Phone -...
I have a blackberry curve 8520 and i need mep code IMEI:357828.04.174194.6
HI Tarek Khaled listen do this first. Take the battery out of phone. Next take your sim card out. Now put the sim card in your phone first. Next you put the battery in the phone. Now you reboot the phone back up. If you have the bb desk top manager on your PC. Plug your phone.in and do an application on the phone. This will help you with the phone. Now you do have one more option. You can backup your phone and then do a master reset on your phone.After you finish the master reset on your phone. you can do a restore on your phone to get all your information back on the phone.
Oct 08, 2011 | RIM BlackBerry Curve 8520 Smartphone
LOAD BLACKBERRY 8320 SIM CARD JUST REBOOTS AND RED LIGHT
This means that the BB can't see the Sim Card. The little sim card is underneath the battery - check and make sure that that the gold part of the sim card is touching the gold parts of the BB. Also make sure the gate is locked in place, it slides to the right when locked. (Slide it to the left to unlock and lift the SIM card gate.)
You should have a SIM CARD, if you don't call your cell company..
Nov 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Forgot paasword to unlock blackberry curve 8330
unlock your Blackberry eaisly with Blackberry Imei Unlock code. first call your service provider ask your Blackberry Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry curve 8830 Unlock Code. Buy your unlock code from third party. i hope this information is help you :)Good Luck
Sep 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
My computer wont recognize my BB Curve when its in the USB
Download and install the latest Handheld Software for your model then open Desktop Manager and run the application loader once the USB cable is connected to the device. 8330 Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=02A32AD2669E6FE298E607FE7CC0E1A0&dl=536515EC27684D1C723C2362546FD6C4
Just fill out the form and the download is free.
Jul 02, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Need to unlock bb curve verizon so i can use it through metro pcs.
U CAN UNLOCK THE DEVICE BY REQUESTING FOR UNLOCK KEY FROM CURRENT SERVICE PROVIDER WHICH HAS COME BUNDELED WITH.
ONCE U RECIEVE NETWORK UNLOCK CODE FOLLOW THE PROCEDURE IN UR HANDHELD
SELECT OPTIONS IN APPLICATIONS --> SIM CARD --> PRESS MEPD --> PRESS MEP2 --> ENTER THE UNLOCK CODE AND PRESS OK TO UNLOCK THE BLACKBERRY DEVICE.
May 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry 8310
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
4. Take in.
Aug 09, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
AT&T Blackberry Curve 8300 Smartphone Logo
1,002 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
