THE SOFTWARE TO CONVERT VIDEO AND AUDIO FOR PANASONIC SV-AV 20 POCKET CAMCORDER
SOURCE: Transfer of video from Panasonic NV-GS50 tape to computer
You will need a firewire card in your PC and firewire cable to connect your camera to the PC. you will also need a software like Windows movie maker which can help you to transfer videos from your camera to the PC.
SOURCE: Panasonic D-Snap SV-AV100 Camcorder. No picture on LCD screen
Just to check - give the manual a read through but I suspect this is a component failure and needs a repair job.
SOURCE: How to download video from panasonic nv-gs15 to Computer
first of all you should have your cd driver came with camcorder and as far as i know your driver isnt compatible with vista so better try to use windows xp. install the driver, plug your camcorder using your usb. upload your videos from your camcorder to your pc using ULEAD MOVIE MAKER. edit it and save it with any various types of videos. finish!
CHARCOIS
SOURCE: Conversion of .mod file.
How to convert .MOD file to mpg, avi, wmv, mp4,mkv, flv and other common video formats?
People who own JVC MOD camcorders, Panasonic MOD camcorders or Canon MOD camcorders encountered the same issue with--- what to do with the MOD files---the God forsaken video format. And they hope that there is a magic tool to convert the recorded .MOD file type to mpeg, avi, mkv, flv, mp4, wmv or whatever more common, so that they can put camcorder video on Mysapce, Google video, Hulu later to share with more people,...and thers is another headache thing is that most major video editing suites seem to unwillingly accept the MOD format. even windows video maker, i have to say it's too complicated to use
Someone successfully made it simply by changing the extension from .mod to mpg, but for most people, they just failed only to find there is no audio after the extension is changed, or the changed one doesn’t allow you to import these files into Windows movie maker, not to mention upload some video to Youtube.com or Facebook.
any simple soulution? There is a very simple program that convert .mod NOT ONLY to mpg but many others like avi, mkv, flv, mp4, wmv, rm, mov, dv, mg2 and swf. MOD converter is the one shoot all the trouble. This excellent mod conversion tool is not just a converter but also a video editing tool. From now on, with the MOD converter you can enjoy your mod video on many media player, even on portable devices like blackberry, Gphone, PSP, Creative Zen,etc.
Things will be easier if you take a moment to finish reading the Step by Step on how to convert .mod to mpg, avi, wmv and others
Step by Step
How to convert .mod to mpg, avi, wmv and others?
Step1 Turn on your pc. Download and install MOD converter
Click here to download and install it by running iOrgsoftTODconverter.exe
Step 2: Turn on your camcorder and connect it to pc. Import the .MOD file onto PC.
Run MOD converter; select the .MOD file you want to convert by clicking the Add or File button to load MOD info. Click the profile button to define the output video format.
Step 3: click the Edit button to set detailed info for the desired video.
A. Click the Trim button to set the length/range of the video that need to be converted.
You can choose a part of a MOD or the whole one to convert
B. Click the Effect button to tune the saturation, contrast, brightness values and make sure are the one you preferred, preview the change on the screen.
C. Click the Crop button to cut the unnecessary part or black part of the movie.
D. Select .AVI or .MPG and select the directory that you’d like your file stored to.
Step 4: Convert video
After all settings is done. You are ready to start conversion. This step will take you a while to carry out the conversion process, the time vary with different parameters you set.
MOD converter is a package tool, whcih actually includes mod to mpg mod to mp4 mod to avi mod to wmv mod to 3gp mod to mov mod to ipod mod to iphone mod to psp mod to iriver mod to creative zen mod to apple tv mod to blackberry mod to zune
Wait a minute, if your exported camcorder video is in a .tod extention file style , it doesn't matter, we have TOD converter .
SOURCE: how do i upload pictures from the panasonic
According to this description on Amazon, your model uses SD memory cards:
http://www.amazon.com/Panasonic-SVAV20-Digital-Camcorder-Camera/dp/B00008OLBN
Then you should have 2 options:
(1) The easiest is to remove the SD memory card from the SV-AV20 and insert it into an SD card reader (many available, starting from below $10). The SD card reader will have a USB connector so you can plug it into a USB port on your computer. Your computer (Windows or Mac) should recognize that you've inserted this and show the data on the SD card as a removable storage device.
(2) Clunkier option is to use the USB cable that typically comes with digital cameras -- these require the camera to be turned on. If you're unlucky, you may have to install camera-specific software on your computer to recognize the device. Since I hate adding extra software to my computer, I far prefer option #1 above, which works universally.
Hope this helps.
