Question about Onkyo TX-DS555 Receiver
No Power The standby light is on, but receiver doesn't power up -- either by switch on front or by remote. There is no display & no operational mode is functioning. A blown fuse has been suggested, but I see no access panel for a fuse. I've checked the surge protector the receiver is plugged into & see no problem there.
  • Anonymous Jan 08, 2008
    tx-sr502 av receiver no power stand by light only
  • Anonymous Mar 30, 2009
    i have the same problem, but the fuse is fine.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 35 Answers
The standby light is on, indicating CPU is now working.
but receiver doesn't power up -- either by switch on front or by remote. There is no display & no operational mode is functioning. This means the power on relay RL901 isn't ON, perhaps. Follow these steps:
(1)download TX DS555 service manual
(2)Unplug the amp
(3)open the amp cover(4)check the AC inlet board, PS6303
(5)see P.31 B(vert.)D(horizon.)(6)Check R922, R923 ,Q921 ,C922, RL901 and a T-fuse,thermal fuse, located at the primary side of the large transformer, ETC-6304.
Posted on Dec 10, 2017
simplemitch
  • 752 Answers
SOURCE: power works but receiver will not stay on
The outputs are blown and will require repair.
Posted on Dec 18, 2007
SOURCE: Onkyo TX-DS777 Problem
man I think i have the same problem....
i push the power button but immediatly the LED turns off. I cheked the fuse but thats not the problem. Please if you solve your problem let me know...
my e.mail adress soy_robertog01@hotmail.com
sorry if you dont undersatnd me in some parts..im not very good writting english haha sorry..
Posted on Jul 29, 2008
  • 4234 Answers
SOURCE: Onkyo TX8211
The most likely problem is shorted output transistors. This is a straightfoward repair for any shop that works on audio gear. Expect a parts cost in the $40-$50 range.
Dan
Posted on Aug 13, 2009
Testimonial: "ok. i was expecting much worse news! thanks a lot for your help!"
  • 17 Answers
SOURCE: Only the front speakers work none of the surround speakers
If you are still covered by the warrenty, then you may be able to get it fixed at no cost.
Otherwise get a qualified technician (I say this to cover my but rather than suggesting that you open it up yourself) to open it up and check the fuses inside.
Posted on Aug 17, 2009
smarthome2
  • 1114 Answers
SOURCE: Hello, My receiver wont come out of
If you push the power button and you hear it "click" that means it's getting power. Now, that being said... Couple things to check: first: disconnect all speaker wires at the receiver and attempt to power up, if it does, that's a good sign that your receiver is ok and your problem lies in the speakers or in the speaker wire. If you still can't get it to power up, pop the top of the unit. Most receiver's have 6 or 7 #1 phillips head screws on the sides and rear of the receiver. Pull these off. Look directly at the area where the power cord plugs into the unit (make sure the unit is unpluggged) There is usually a fuse right nearby. If it's a white fuse or gray fuse you may need to do a quick continuity check with a meter to test. If your familliar with meter's, just switch it to continuity/tone. If the fuse is good, you will hear a tone from the meter. If not, there's your problem. If your not sure how to test with a meter, either take it to Radio Shack or similar store, ACE hardware etc. they can test it for you and will generally have replacements in stock. If the fuse is good, your speakers are disconnected and you still have no turn on, your receiver needs to be serviced. If that's the case, whether you service or replace the receiver, get a good "Theater" line conditioning surge!!! like Panamax, Monster, APC, or Furman. A good unit will start around 250. Small price to pay for saving expensive electronics! Hope this helps. If you need further help, just post a comment and I will be glad to help.
Posted on Dec 05, 2009
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
Sylvania tv manuals model lc195sl9
http://www.searspartsdirect.com/partsdirect/user-manuals/lc195sl8-sylvania-parts-tv+lcd-manual [] Control Panel
POWER (pl 1)
Press to turn the unit on and off.
INPUT SELECT (pl 3)
5. SETUP (p11)
Press to display the main menu.
6. infrared sensor window
Receives infrared rays transmitted from the remote
control.
7. power on indicator
Lights up when power is on.
8. standby indicator
Lights up in standby mode.
May 02, 2014 | Televison & Video
The TV keeps going into standby mode , comes back to proper picture and with-in 15-20 seconds goes back into standby mode. It happens continueously.
May I know if the standby led light at the front panel is blinking, if so please count how many times it will flash to determine the error code? If not follow the steps below.
In standby mode press the button of the remote control in sequence, " Display ", " Channel 5 ", " Vol (-) ", " Power ". Self diagnosis screen will displays. Le me know the result.
Jdvillanueva
Sep 02, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
How to reset the recever?
Place the receiver in Standby mode (press the front-panel Standby/On Switch so that the Power Indicator turns orange).
Then press and hold the front-panel OK Button on the Receiver ( not remote ) for at least five seconds until the RESET message appears in the display. Then press OK. The system will go to factory default. All your settings will be lost like FM stations / Sound settings etc: .
Apr 03, 2011 | Harman Kardon AVR 35 Receiver
TURN OFF LOCK. I AM IN MENU MODE, BUT WHERE IS THE ON/OFF BUTTON LOCATED?
Power on…Turn the POWER switch ON.
If the POWER switch on the backside of this recorder is
turned OFF, it is not possible to use any of the functions.
Turn the POWER switch ON before operation.
Power off…Turn the POWER switch OFF.
Standby Mode and Display Shut Off
If the recorder is stopped for 5 minutes or longer during recording or playing, it goes into
Standby (power-save) mode, and the display shuts off. To exit Standby mode and turn on
the display, press any button.
Locking a file keeps important data from being accidentally erased.
Locked files are not erased when you choose to erase all files from a folder.
In Menu mode selection... On, OFF
On: Locks the file and prevents it from being erased.
OFF: Unlocks the file and allows it to be erased.
Feb 02, 2010 | Olympus WS-100 Digital Voice Recorder
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
My rxv 1800 wasnt used for probably a year but was left plugged to a wall outlet during that time it wasnt used. when i came home last week, i switched it on but immediately shuts off after a second. when...
r this one: Switc off your receiver using the main power button on the front face. Hold the the Effect button and the Direct button, and turn the main power ON.f it ain't working, try this one: Turn your receiver ON and, while holding down the [VCR1] button, press the [STANDBY/ON] button. "Clear" might appears on the display and your receiver might enter Standby mode.
Hope it does.. With your receiver in the Standby mode, hold on STRAIGHT (EFFECT) on the front panel and press STANDBY/ON.
* The ADVANCED sETUP menu appears in the front panel display.ress STRAIGHT (EFFECT) to select the desired setting.
RESET = To reset your receiver to its factory presets.
CANCEL = To cancel without making any changes Press STANDBY/ON to confirm your selection.
* If you selected "RESET", your receiver is reset to its factory presets and switches to Standby mode good luck
shaun
Aug 24, 2009 | Yamaha RX-V1800
Lexicon RV-8 wakupe failure
Did you try this....
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
POWER MANAGEMENT ON, OFF
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
position.
2. Attempt to power on the RV-8 with the front-panel Standby
button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
Apr 05, 2009 | Lexicon RV-8 V2.0 Amplifier
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057561.pdf . The page is also available here: https://www.manualslib.com/manual/197512/Yamaha-Rx-596.html?page=11#manual .
I hope this helps.
Jun 28, 2017 | Yamaha Audio Players & Recorders
74 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
