Question about Cameras
Wont read memory card
Camera says the memory card is locked and menu does not let me unlock.
  • mtorrisi Jan 30, 2009
    please explain..
  • 928 Answers
The only option in this case is to format the memory card in a computer. After doing that put the card back in the camera then format it again using the camera
Posted on Dec 08, 2008
Where is lock on sd memory card
There's a small slide switch along one side of the card. Slide it toward the contacts to unlock it.
Mar 30, 2017 | Cameras
What model Canon camera? What type and size memory card?
Jun 02, 2013 | Canon Cameras
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
Powershot s3 is memory card locked
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 11, 2012 | Canon PowerShot S3 IS Digital Camera
I have the samsung s630 and i have taken some pictures on it before i got a memory card. i want to save them to my memory card, but when i insert the memory card those photos wont show up. how do i get...
If you remove the card from the camera and connect the camera to your computer with the USB lead, you should see the camera's internal memory as a disk drive on the computer. If there is a memory card inserted, you will see that memory instead.
Unlocking individual pictures is done with the same function that locked them. It is probably on a menu available when you are viewing the pictures on the camera.
Oct 20, 2010 | Samsung S630 Digital Camera
Samsung PL50 camera wont unlock memory card
There is a little sliding switch on the side of the memory card. Make sure it is not on lock.
Mar 01, 2010 | Cell Phones
CARD LOCKED appears oo screen, camera wont work?
Does this camera take a memory card, separate from the built-in memory of the camera? If so, remove that memory card and look closely at all sides and edges, to make sure that there is not a read-only protection switch on it.
Many of these memory cards have tiny switches, sliders back and forth, that protect the memory from being erased.
If you slid that switch into the locked position without being aware that it is there, and without knowing that you did, then the error message makes sense.
Remove the memory card and look at it very carefully.
-a.
Dec 10, 2009 | Samsung Digimax L730 Digital Camera
Reads memory card is protected but, it is not
It's the cards, but it's not necessarily a problem.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 06, 2009 | Kodak EasyShare C653 Digital Camera
The card is locked]
there should be a little swith on the side of the card. switch to the opposite and then try
Mar 28, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
Cameras Logo
437 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
