Question about Pentax Optio S5i Digital Camera
Optio S5i - Memory card poor contact
I have an Optio S5i, and until recently I was very hapy with it. Now when I switch it on, I get a memory card error. If I flip the lid on the memory card and depress it right into the camera and restart, it works fine. I'm reluctant to open it to try and fix this but the quote from Jessops was 100 GBP just to look at it, a lot for a misaligned contact. Has anyone else fixed this?
  • Petit Sauvage Feb 24, 2007
    I tried 4 different cards - all the same result
    Novelist:
  • 107 Answers
I have never seen an SD card based camera with a memory card contact issue. This doesn't mean thats not whats wrong, however it is more likely that it is the contact between the SD card housing and the board that it is mounted to. Either way these cameras are fairly complex inside and unless you have good mechanical aptitude you might be taking your camera's life into your hands. 100GPB is way high for a minimum labor charge, try to find a provider who will either evaluate it for free or a low minimum labor charge. This repair would cost around 125 US total at my shop. David Millier Advance Camera Repair
Posted on Feb 24, 2007
  • David Millier
    David Millier Feb 24, 2007
    Alright, reading my previous response I see that I did not make it clear what I was referring to.
    I think it is most likely that your problem resides not in the actual contacts which touch the card when you insert it, but with the connection between that whole SD card slot assembly and the circuit board to which it is mounted.
    David Millier
SOURCE:
Can I use 4gb memory card in pentax optio s5i support
No. The S5i works with SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards.
May 06, 2014 | Pentax Optio S5i Digital Camera
How to unlock camera
It's not the camera, it's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 23, 2010 | Pentax Optio S5i Digital Camera
Upgraded to Windows 7 & it no longer recognises my Pentax Optio S5i camera ? Cannot download my photos since installing Windows 7. Can we get updated software for my camera ?
HI there there try to download the windows 7 camera driver from pentax website. It will start work then. Another way is remove the memory card & put in in a card reader then you can also transfer all photos from card to computer For further help ask me . Thanks.
Mar 23, 2010 | Pentax Optio S5i Digital Camera
Error message Built in memory full. Also won't read memory card.
You need to format the internal memory with no card in the camera. Then, you need to format the memory card in the camera.
Feb 17, 2010 | Pentax Optio S5i Digital Camera
Can a pentax optio S5i support a 8GB memory card? Do I need to download a driver to support an 8GB memory card/
No the Pentax Optio S5i does not support an 8gb memory card.
8gb would be an SDHD card, the S5i came out before SDHD so it does not support them.
Standard Secure Digital Cards come up to 4GB in size so you could use one of these. The highest standard card I have is 2gb and that is fine in mine.
My S5i locks up if you put an SDHD card in.
The only firmware update that Pentax supply does not effect this, SDHD needs different hardware.
Jan 02, 2010 | Pentax Optio S5i Digital Camera
Digetal carara card lack
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 19, 2009 | Pentax Optio S5i Digital Camera
When Iturn it on the screen go blank and say card lack it is a pentax Optio S5I digetal camara
Transfering photos from pentax optio s5i camera to p.c.
You should be able to get the software from the manufacturers website. Most manufacturers keep the software up there for free all you have to do is download. Otherwise I personally prefer to use a USB card reader. All you have to do is unplug the memory card from the camera and insert it into the reader. The computer then sees the card as a jump drive. The card reader is much easier in my mind because you don't have to learn the less than fabulous software most manufacturers use for their cameras.
Aug 26, 2007 | Pentax Optio S5i Digital Camera
Pentax Optio S5i Digital Camera Logo
114 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
