Vy commodore 2002
SOURCE: Fitting a Tow Bar
just put your tow bar up to the frame, it already has threaded holes in the frame to fit the bolts that came with your tow bar to it. It's really easy. everything should line up perfect
SOURCE: tow bar wiring
hi! first check the plug on the van,the socket on the car, then the little blue push connectors the fitters use,last but not least the lamp tabs on the lamp holder!
SOURCE: i am not sure how to install a tow bar to my vs
ive just done mine u need the tow bar that goes under the car and there are only 4 easy accesable bolts to undo and to put it on your car just up the from of the fuel tank to the passanger side there are too bolt holes and once u have done them up towards the front of the boot the other too will alighn and all u have to do it just do the bolts up there in the boot if u lift the carpet up
SOURCE: I want to tow a 1999 Buick Regal behind 2002 Ford
Not a good plan. Rent a car dolly from u-haul or somebody.
The reason is that the wheels will move certain internal parts of the transmission that need lubrication, but that comes from the engine running the pump. That is why some towing companies that have to tow cars with the drive wheels on the ground will sometimes leave the engine running and the tranny in neutral, but that won't work for long distances
Testimonial: "Excellent - thanks for the help."
SOURCE: asr light came on after fitting tow bar
Dear Nick,
I Have No Idea On How To Help. Try Going To 101projects.com, ehow.com Or Even YouTube.com. I Hope Your Question Is Answer There.
Sorry,
Alex :o)
