Question about Sims SVR-H905 Handheld Digital Voice Recorder
Need driver (?)
Do I need a driver for this thing ?? Windows does a search for it but doesn't find it. SO I can't access it via USB. I looked around the net but the manufacturere seems to be absent........ thanks.
0 characters
1 Points
How do I get Olympus DS-4000 to work on Win 8 64-bit
do you have programs files (86) in your PC "C" drive menu menu? If yes that;s where yiou should install the software. That's because it;'s a 32 bit on a 64 bit.
Oct 17, 2013 | Olympus DS-4000 Digital Voice Recorder
I can't find the drivers for my Olympus Digital voice recorder VN-2000PC. What can I do? I can't tranfers my audio files to my PC.
Do you need the software/drivers for the VN-2000PC or the VN-2100PC? The software for the VN-2100PC is available here: . Select your OS and you'll find the software.
The VN-2000PC doesn't connect to the computer via a USB port. To transfer your files to a computer, connect the earphone jack to the line In (blue) jack of the computer with a 3.5mm to 3.5 mm audio patch cable. Use a program like Audacity to record the audio track during playback. Make sure to set the Audio input to Line In. (In Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click Manage Audio Devices. Then select the Recording tab and set the input device.) Then set the recording device in the software as well. Click the Record button in the software and then start the play back on your VN-2000PC. You should see a flat line for a bit then see a wave form start. If the line stays flat, you haven't set the Line In device properly.
I hope this helps.
Sep 01, 2012 | Olympus VN-2100PC Digital Voice Recorder
My Zoom H2 recorder is not recognized by my new computer with Windows 7. What can I do to solve this?
No solution, just a workaround. I have used the H2 with firmware 1.90 successfully with Windows 7, but lately the H2 is not recognized anymore. Built-in obsolescence maybe?
Anyway, I just take out the card and put it in a card reader. It is faster also. Card readers are cheap.
Sep 07, 2011 | Zoom H2 Digital Voice Recorder
Vr5230-acomputer will not recognize my rca voise recorder
if it came with a driver..just run the driver again in the computer and be sure the installation goes OK ..After that restart the PC ..and plug the should see it if this was the issue ..Another thing is to plug the device powered and on ..and check the screen of the recorder ..cause sometimes you have to confirm the pc connection ..or ..card reading ..from it ..
If you do not have a driver just check the manufacturer's site..and see if it needs one or it is a plug and play device ..if it is a plug and play ..try to reset the recorder..(look for the reset button in a hole accessible with a stylus or sharp object ) or the menu the reset to factory settings ..
In the last case you will have to reinstall the firmware in the recorder cause it is damaged and not seen by the usb port ..This is the case for those that are plug and play ..and have the driver in the root folder and accidentally deleted..
If it is not damaged or so ..follow these instructions to install the driver built in ..
anyway ..plug it and check the my computer folder and see if it has a separate drive for its root (may be in the disk drive sections )
Jan 17, 2011 | RCA VR5230 Voice Recorder
Window 98 Professional does recognize Panasonic RR-US395 since it was removed from the usb port accidentally before being removed properly. I can see that the recorder is connected but can't find the files...
Windows 98 Professional?
I don't think there is such a version. It's probably either Windows 98 or Windows XP Professional.
If a reboot does not help, the simplest thing to try is to reinstall the device driver registry entries for the USB port.
Assuming you have Windows XP, right-click "My Computer" and select "Manage". Under "System Tools", select "Device Manager". If Windows is detecting problems with any of the device drivers, the Device Manager entry will be flagged with a exclamation point caution sign. Otherwise, you can try removing all of the entries under "Universal Serial Bus controllers". To remove the entry, right-click it and select "Uninstall". Remember, this only removes the entry from the registry. Unless the drivers are corrupted or missing, you will likely not need the install disk to reinstall the entry. Once you are done, reboot and Windows will detect the USB controller(s) does not have an entry and will prompt you to reinstall it. Take the option to let Windows find the drivers for you. If this procedure does not work, try uninstalling and reinstalling the drivers for the device. If that does not work, you likely have a hardware problem - bad cable, bad connection, etc.
If you do indeed have Windows 98, it's been a while, but the above procedure should be similar.
Jun 12, 2009 | Panasonic RR-US395 Digital Voice Recorder
Olympus VN-4100PC does not register even with Vista updates
Well, I too have done the aforementioned things, and I still can't get my vn-4100pc to register. Anyone?
Jul 02, 2008 | Olympus VN-2100PC Digital Voice Recorder
OLYMPUS DS-330 Drivers
Hi Aklas.
Olympus DS-330 voice recorder drivers (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
Nov 05, 2007 | Olympus DS-150 Digital Voice Recorder
Driver for windows vista home premium
I have Windows Vista Home Premium. I do not have my original Olympus disc. I downloaded the driver from driver guide ( > installed driver (in this case pencam.exe. After installing the Olympus software I hooked the USB cable up, turned on my w-10 recorder and let Windows begin it's search.
I manually pointed it to the pencam folder where it proceeded to load the drivers successfully. I am now able to transfer my files successfully. Hope this helps in some way.
Oct 17, 2007 | Olympus W-10 Digital Voice Recorder
Transfer datas from Denpa to computer
Might be able to help you out but need some more information...
1. What type of PC (IBM/Mac) do you have?
2. What OS (Windows 95/98/NT/ME/XP/Vista/Leopard/Linux etc.) are you operating on?
3. Do you have CD that shipped with unit and USB cable?
4. Does your computer 'see' the unit as a removable drive when connected?
5. What model Denpa is it?
I'll check back in a few days to see if you're still looking for a solution - have you successfully transferred files before?
Oct 10, 2007 | Denpa USB-24 Digital Voice Recorder
Denpa drivers required for online download
Depends what OS you are using. If you are using Windows ME/2000/XP/Vista then you do not need drivers for device to be recognized by PC when it is connected via USB cable (operating system will automatically work out what drivers are needed and configure so that the PC 'sees' the device - once seen it will show up in my computer as 'removable disk' icon).
If you are using Win98 then you need to install the driver. I haven't found anywhere on the Web where the files are located but they may be on the Windows 98 CD itself (they are identified as HB_UDISK_DRIVERS).
For example, from the installation CD the full path would be:
D:\HB_UDI~1\WIN98\HB__UDISC.INF where the CD-ROM drive is called the D drive (depends on hard disk configuration).
There is another question on here where someone has posted a link to a site to download software...not sure if the device driver files are available there. Note that the drivers merely enable your PC to recognize the device - the won't be any use in encoding/decoding/editing the files; that's done by separate software programs.
Good luck. Repost if you're having no joy...I may be able to dig out my installation CD and burn/mail you a copy. I'll check back in a week or so.
Nov 10, 2006 | Denpa USB-24 Digital Voice Recorder
Sims SVR-H905 Handheld Digital Voice Recorder Logo
35 people viewed this question
Top Sims Voice Recorders Experts
David Burkhart
David Burkhart
Are you a Sims Voice Recorder Expert? Answer questions, earn points and help others
