Question about Sony KDSR50XBR1 50" Projection HDTV
Sony KF50WE620 Mirrors are dirty or smuged.
I noticed after i removed the lamp from my sony kf50we620. that the mirrors seem to have a little smuge or are dirty. is there any way to clean them? also noticed a little soot around the mating surface where the lamp housing make contact with the mirror housing is this normal?
  • Dennis Emerson Dec 10, 2008
    is ther a cleaner i should use also?
    Genius:
  • 1,199 Answers
Clean with a micro-fiber cloth
Posted on Dec 08, 2008
I have a sony KDS-R60XBR1. The lamp burned out so I ordered a new one. When I took the old one out, I noticed the area directly in front of the lamp, the first thing the lamp shines into, is a little dirty...
Use a eyeglass cloth or LCD screen cloth. Use NO solvants on it. Just dry cloth. ALSO goto the settings menu and put the tv in HIGH altitude mode. There tv's get too hot and the light engines go out. Green or blue tint. or dots. It also helps the lamp last longer.
Jun 02, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
How long is the life of projection lamp? and how much is the cost?
Lamp life is approx 3000 to 3500 working hours and Sony original lamp cost would be around $200
Aug 12, 2010 | Sony Grand WEGA KF50WE620 Television
5 blink red lights
Replace your Lamp # XL2100u Mats has them in stock 1-800-628-1118
Mar 24, 2010 | Sony Grand WEGA KF50WE620 Television
My sony wega kf50we620 has blue pixxels showing on screen
You have a bad light engine call sony see if it is on their extended warranty list.
Nov 23, 2009 | Sony Grand WEGA KF50WE620 Television
Mitsu 65" DLP-picture seems washed out
Most likely cause of your trouble is dust on the small mirror inside you set. Your DLP set has 2 mirrors not including the DLP chip itself which has about 500,000 tiny mirrors. The 2 mirrors reflect the DLP chip image to the screen you view. The first is the main suspect it's about 4inches by 7inches. It's mounted on the bottom center facing backwards. This mirror faces slightly up and somtimes after time dust, smoke, dirt settles on it . The second fills the space of the entire back of the cabinet but it faces down and takes alot longer to get dirty.
The compartment is sealed but dust seems to find it's way in. If you remove the screws that secure the screen assembly from the top , sides and bottom. Make sure to have a friend available the screen assembly is delicate when it's not mounted to the cabinet. You can remove and clean the mirrors. These mirrors are glass and you can use glass cleaned. Don't use glass cleaner on the screen it's plastic. You can clean it if necessary with plastic cleaner only. Probably not needed.
Good luck.
Apr 23, 2009 | Mitsubishi Televison & Video
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
