Question about Carrier 38CKC036 Air Conditioner
My heater won;t work
My gas pack heater was working fine yesterday but today it will not light off, I usally here the ignitor clicking before it fires but now it doesn't do anything, the unit is only three years old
  • 3 Answers
Check induction fan motor first...then check the rubber tube and the switch it ataches too. this switch should close if the induction motor is running...but also...it HAS to be open before start up.
Posted on Dec 09, 2008
Heater
It sounds like the ignitor is not working, Since the heater is not detecting a flame it goes to lockout. Check the ignitor wiring to see if it is in good shape. Sometimes the connection where the wire (from the IID) connects to the ignitor gets corroded.
It could also be the IID which makes sure the safety loop is complete before calling for heat and sending current to the ignitor. Good luck with it.
Jan 11, 2014 | Mr. Heater Natural Gas Garage Heater -...
My furnace won t ignite
My baseline rule of thumb is: gas appliances tend to blow up if improperly repaired, so I call a repair man. Could be something as simple as a broken thermocouple (it doesn't believe it's achieving the appropriate temperature and so it keeps trying to light something that's already lit and not starting the main burner) or something as scary as a gas leak that's reducing the pressure to the burner. Best to let a pro handle it.
Oct 28, 2013 | Heating & Cooling
Why does my Kozy World natural gas wall heater set off fire alarm system?
Most new heaters give off a smell or some light smoke which needs to be burnt off the first time it is used it may smoke , this may be why your alarm is going off , run it with a window open to remove smell etc .
Feb 12, 2013 | Heating & Cooling
Heater will not light
There are several things that can cause this symptom. If you have a volt/ohm meter and call the Hayward technical support at 908-355-7995 they might be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Hayward H Series Induced Draft Abg 100,000...
Gas furnace model # gmb100-4 will not fire up ignitor working clicking sound afterwards but no firing up. Whats wrong
If induced draft motor comes on then ignitor tries to light but no flame I would change control board.I've had the same problem on several goodman heaters and all but one required new board. The other one was a bad gas valve but I would try board first. Hope this helps. Thanks
Nov 07, 2010 | Goodman GMS90703BXA Heater
Automatic gas shutdown light comes on. replaced ignitor that was not glowing. worked friday. today troubleshooted new ignitor is fine. replaced ignition control box. still no power (voltage) going to...
This sounds like your fan prover (air switch)
check switch continuity, and air switch tubing.
Replace if neccessary.
Sometimes these vinyl air tubes just melt
Nov 01, 2010 | Jandy Laars Lt 250,000 Btu Heater
Summit ignitor Worked fine yesterday, today no ignitor.
Check your ignitor wires for broken or disconnected connections.
May 14, 2010 | Weber Genesis Gold B Grill
Carrier 38CKC036 Air Conditioner Logo
165 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
