My Samsung HD TV 50" progressive Monitor goes off and turns dark
HD tv 50 inch Progressive Monitor after turning it on, only lasts about 45 minutes on, and the picture goes off and turns dark maintaining only the sound.
The same will occur if I turn it on again. It does not remain with the pircture for more than 45 minutes to an hour.
Thank you,
Clayton
Samsung HDTV will stay on when turned on the temp lamp and timer light are flashing continually. what should I do to eliminate this problem?
Posted on Jul 01, 2012
SOURCE: Samsung HLR5067W
Faulty lamp could be, there is also a little blue switch behind the lamp door that needs to be in the down position.
Posted on Nov 19, 2007
premtech
  • 934 Answers
SOURCE: toshiba projection tv 50 inch
Need to test F470 and F850 for open.. Simple continuity to see if either fuse is open.. If F 470 is open replace it and C884 and if F850 is open you probably you may need to replace the two convergence amps STK392-110... Large black Ic's screwed on an aluminum heat sink...
Bill
Posted on Feb 03, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
  • 298 Answers
SOURCE: I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Posted on Jan 16, 2009
  • 94 Answers
SOURCE: 56 INCH SAMSUNG TV TURNS ITSELF OFF. TV IS 2 YEARS
please check the timer setting in your T.V
Posted on Jul 04, 2009
Have a 50" Samsung HDtv progressive monitor, can anyone help me with what this means?
It means you have an fantastic tv it wont stop you doing anything so dont worry just enjoy your tv
Oct 10, 2013 | Televison & Video
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
No Hd
Make sure its in component2, I tried using progressive scan in component1 and it goes all haywire, turn it off and component1 works fine but is not in HD. Same device in component2 in progressive scan works fine. Had to buy an amplified switch from RadioShack to hook up more than one progressive scan device to component2. This is of course assuming that your using component inputs and not hdmi or something else.
Oct 04, 2007 | Protron PLTV-32 Television
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Turn off progressive scan without progressive tv?
This is not a solution but it is a big thank you to whoever posted the 3/20/07 solution to getting progressive scan OFF. I tried holding REW & FF in for 5 sec. and it worked. Thanks Again
Mar 20, 2007 | Samsung DVD-V4600 DVD Player/VCR
Televison & Video Logo
535 people viewed this question
Top Televison & Video Experts
