Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
My Krazr won't work at all
My K1 will not work at all. It just "quit"... I press the power button, and the keypad lights up. When I release the button, the keypad goes off. The phone will not turn on - it seems "dead" but is charged...
  • Mischou Apr 18, 2009
    Exactly the same problem - completely black screen, fully charged phone, if you press the red button it powers up for few seconds to flash the "Hello Moto" screen, then back to black. Rogers tech says the software crashed. No way to recover data, except possibly through a forensic data recovery business - for a lot of $$$. BEYOND disappointed and upset.
    Brigadier General:
  • 7,752 Answers
Try a new battery and also try replacing the flexcable
Posted on Dec 26, 2008
How do you program RCA Systemlink 3 RC303-C for Television Model F27255BC
Without codes:
  1. Turn on TV.
  2. Press and hold CODE SEARCH until all device buttons light, release button.
  3. Press TV button. TV button will stay on.
  4. Press POWER repeatedly until TV turns off.
  5. Press ENTER.
With codes:
  1. Turn on TV.
  4. Using number keypad enter code for TV.
  5. Press ENTER.
Nov 17, 2016 | RCA Televison & Video
The CHILD LOCK light came on and I cant get it off. Pressing CANCEL does nothing. How do I fix it?
Usually you need to press and hold a button or a pair of buttons to toggle the Child Lock function. Without the model number of your dishwasher, I can't be sure if this will work on your machine. It did work on the old Kitchenaid I had. Press and hold the Energy Saver/Dry button for 4+ seconds. If the light goes out, you have released the front panel lock.
On some models, you needed to press and hold the Air Dry button. However, you may need to look for writing in a small font that will indicate the correct button/key combination to release the front panel lock.
If pressing the appropriate button for an extended time doesn't work, then your keypad may need to be replaced. The signal isn't being received by the control of the dishwasher. (Alternatively, the wiring between the keypad and control unit or control unit, itself, may have an issue.)
I hope this helps.
Feb 26, 2016 | KitchenAid Dishwashers
I want to change current keypad code linear LD050 model
To change the keypad code.
Step 1:
Erase the current code - On the upper right hand corner of the left hand side of the unit, you will see a "learn" button.
Press and hold the "learn" button for 12 seconds.
When you release the learn button, the red light above the button will blink 3 times and then come on bright for 15 seconds.
When the light goes out, the memory in the operator is erased.
Step 2:
Learn a new keypad code.
Press and release the "learn" button.
The red light will come on. You now have 15 seconds to complete the next task.
Go to your keypad and enter your desired code (1 to 6 digits long)
press start/stop on the keypad.
The red light will blink when the code is successfully stored.
Don't forget to re-enter all of your hand held remotes into the memory:
Press and release the learn button. When the red light comes on, press the button on the remote you wish to update.
Repeat for other remotes. By the way, If you hold the learn button down for 10 seconds, you'll have to start over and the memory will be erased.
Nov 14, 2012 | Home Security
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Cannot program Dish IR remote l03602
adeline_roll
You didn't specify if you are trying to program the remote to your TV or receiver. Is it a replacement remote or did it just quit working? I have provided instructions on how to program to your TV or receiver.
Address to receiver:
Remote: All Other Remotes
  1. Go to System Info screen (depending on receiver - press System Info button on receiver panel or pull smart card out till System Info screen appears on TV screen).
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Remote: Basic Remote (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Press and release the TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the OK button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Please let me know if you have any other questions or problems. Thanks.
Ray Calo
DISH Internet Response Team
Jun 23, 2011 | DISH Network IR Remote Control
We just moved in our house in January and our keypad on our 1/2HP Liftmaster stopped working. I have changed the battery and when I try the code the backlight blinks several times but the door never opens....
Try programming the keypad by doing this:
Press and immediately release the smart/learn button and then walk over to your keypad and key in any 4 digit code you like and press enter. If this doesn't work you keypad has quit.
Aug 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
What is the code for philips tv using RCA universal remote control ??
just follow the steps below
1. Manually turn on the TV.
2.Press and hold the CODE SEARCH button until the
INDICATOR LIGHT lights, then release the CODE SEARCH button.
3.Press and release the TV button (The INDICATOR LIGHT will blink then remain lit).
4. Enter the code using the Number Buttons. After your code is entered, the INDICATOR LIGHT will turn off.
code list for philips :
003, 004, 008, 012, 019, 062,068, 069, 075, 076, 086, 087, 088
5. Aim the remote at your TV and press the ON•OFF button. Your TV should turn off.
6.With your TV on, press CH+. If the TV responds, no further programming is required.
if it works ignore the following thing (quite difficult and irritating one)
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV). The INDICATOR
LIGHT will blink once then remain lit.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have
retrieved all three numbers in code
if you want code list for all devices
download this pdf
Jun 14, 2010 | Televison & Video
My printer quit working. When I plug the wire
Connect the Printer Directly to the Wall socket.
Then Perform the steps given below to reset the printer.
This will remove all the network and fax settings.
if the issue still persists, contact HP for replacement.
Please remove the power cable from the back of the printer.
Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
We have to press the keys on the printer. Release the buttons as soon as the power cable gets inserted to the printer.
Jun 02, 2010 | HP Photosmart Premium C309A All-In-One...
My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Nov 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
189 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
