Question about Intertherm P3RA-048K Air Conditioner
FAN WILL NOT COME ON WITH THE FURNICE.
IT IS AN ELECTRIC FURNACE AND IT WILL COME ON BUT THE FAN WONT COME ON WITH IT. I CAN TURN JUST THE FAN ON SO IT WILL WORK.
  • margaret1952 Dec 10, 2008
    Intertherm E2EB-015HA need complete wiring diagram/schematic from installation instructions.Can't afford t buy,so online at no cost would be greatly appreciated.
  • 3 Answers
Switch t-stat to on, for quick solution...still got problem with relay or something
Posted on Dec 09, 2008
My furnace wont turn off
Well Linda, is it the heat portion will not shut off or just the fan in the furnace that continues to run?? If the heat won't shut off, it will get uncomfortably HOT in your house, if its just the fan.....well, its just the fan.
More than likely its just the fan and it is running continually due to a stuck set of contacts in the control board or in the fan control board, if so equipped. If it is a furnace that is older than 15 to 20 years, it could be a mechanical relay that controls the fan directly off another control in the furnace vestibule that senses heat in the heat exchanger. If its an electric furnace, the first stage heat sequencer could be stuck closed causing continual fan operation and possibly one heat element is also energized. There are also several additional issues that could be the cause.
At any rate, its time to contact a reputable service entity to correct your problem. Good luck, Linda.
Dec 04, 2015 | Heating & Cooling
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Jan 07, 2013 | Goodman Manufacturing Goodman HKR-10C 10kW...
Electric furnace. Just replaced the controller board but no heat. The blower does come on when the thermostat gives the heat command and I was wondering if that means the relays to the furnace coils is...
On a Trane furnace the fan realy must energize before the electric strips will come on. On the thermastat. See if there is setting for electric heat. This will bring the fan on and the strips should come on. First just turn on your heat and and turn fan to on postion if it works you need to set tstat to electric heat mode. Most of the time there is sswitch in the back of the stat that says gas elec. Turn to electric. Rus
Oct 29, 2009 | Heating & Cooling
Tapan furnice not turning on, The furnice start and the lighter turn on the small fan is running and after about half a minute the first eye turn on for a second and then everything stop
Check to make sure the gas valve is on.
If so it is most likely the heaqt sensor that proves the ignitor is on. Replace the sensor.
Next time post your model number, answer will be more precise.
Oct 10, 2009 | Heating & Cooling
Goodman GDT070 furnace pressure swich problem.
Inspect both the intake and exhaust pipes for blockage or debris. Inspect the small tubes that go from your combustion fan to the pressure switch and the tube that goes from the fan to the condensate drain. They all should be clean and dry. Inspect the combustion fan to see if it spins without it scraping on the housing or it may be filled with water or debris. Last, check the air filter and clean or replace.
Furnice shut off
need aalot more info,,,gas or electric furnace is it doing anything at all,,when u call for heat?
Oct 23, 2008 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
