Question about Dell Pocket DJ MP3 Player
Ear phone jack needs to be replaced
Dell pocket dj ear phone jack not making a good connection were can i get it repaired?
  • Anonymous Dec 27, 2008
    Where can I download music from to my Dell Pocket DJ? Use to use Musicmatch and then Yahoo, but cannot find service that recognizes the device.
Dell Pocket DJ (5G) seems to have a "loose" eaephone jack,it plays fine as lond as I hold the jack but gets static and dose not play well if I let it (the jack) go.
HELP!
Posted on Aug 09, 2010
If you know anyone with soldering capability the pads on the headphone jack just need to be re-soldered. Mine did the same thing so I re-flowed the solder joint and now it works perfect.
-Brad
Posted on Dec 12, 2008
4 Suggested Answers
SOURCE: Ear Jack
I had the same problem you had on a Dell DJ 30 I wrapped aluminum foil around my headphone jack and I plugged the headphones in. When I took my headphones out, the aluminum foil got stuck inside the player. I put the headphones back in and tested it and it worked. The aluminum foil is well placed in there and doesn't come out. I just did this a few minutes ago, so I am not sure of the long-term effects of this. Some articles I have read on the internet seem to suggest that this can cause a short-circuit. I am not sure and cautious about this. I will continue to use my mp3 player, but I might discontinue use in my car, for fear of shorting out my car speaker.
Posted on Apr 06, 2007
Kidyubyub
  • 143 Answers
SOURCE: quick question re: Dell pocket DJ 5gb....
From what I have read, yes, it charges via USB.
Posted on May 19, 2008
SOURCE: Dell DJ 30 head phone jack has a bad conection.
Yeah i just fixed mine. Take out the black plastic on both ends. 4 tiny screws underneath, then 2 small metal ends. You will see the board on both ends.
Take out the battery fron the botton. Then TAKE OUT THE SCROLL BUTTON. After that you take out the board. Looking at the headphone jack, you will see 3 small metal connectors inside the jack. try to bend them a lil towards the inside of the connector. I actually put a very tiny piece of metal between the metal and the black plastic in order to force them out.
I was able to fix it, but in the process i broke the scroll button. If you decide to not fix yours and you want to give me the broken dell dj, let me know, i could use the parts.
Posted on Sep 28, 2009
Dell Pocket DJ does not charge using USB Cord
If you find none of this has worked you need to try some other decvie in the same usb port. If it is plugged in and operates correctly, you have narrowed it down to the dj unit. Since the chord has tested good, we should go to the unit itself. Four tiny screws located on the outside of the case need to be removed in order to open it. Carefully remove the hard drive, then the battery.
Now with the cable hooked up to the usb port you will use a meter to check some voltages. Perhaps you have a friend who can help. The batteries should read 3.6 VDC. Measured like that its not a true indication of the state of the batteries, but tell us that the charging circuit is probably working okay.
Put it back together carefully, making sure every connection is properly seated and there is no damage. Try it again, making sure you hold down the button for 3-4 seconds. If you have done all of this, the problem is electronic and at a component level. Suggest you take it or send it to the repair shop dell has.
Ted
Jan 16, 2009 | Dell Pocket DJ MP3 Player
Music form Pocket DJ to computer?
Go to dell.com and click on Drivers & Downloads, when entering your service tag number make sure to enter numbers only, ( mine has a B in the tag number I enterde it as an 8 and it worked)
When you enter your service tag number you will be able to downlaod the driver upgrade for your DJ make sire you dounload the SYSTEM FIRMWARE VERSION 2.20.07.A02.
Click on this link and it will take you directly there, keep in mind I am using my own tag number here
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=8508861&SystemID=PDA_MP3_DJ&os=WW1&osl=en&catid=&impid=
GOOD LUCK AND HAVE FUN WITH OUR DELL POCKET DJ=)
Jan 04, 2009 | Dell Pocket DJ MP3 Player
Dell Pocket DJ 5gb music problem
i need a drivers for my pocket dell dj 5GB model number HV03T
Aug 07, 2008 | Dell Pocket DJ MP3 Player
Dell pocket dj 5mb wont turn on
there is a pin hole to reset it.On the botom side beside the dell logo you will see it.Use a pin to reset.
Good Luck
Jul 07, 2008 | Dell Pocket DJ MP3 Player
Quick question re: Dell pocket DJ 5gb....
May 19, 2008 | Dell Pocket DJ MP3 Player
Headphone jack
I have the same problem with my DJ 30, and it exists with several different types of headphones.
I am thinking about trying a mono to stereo adaper, where the plug is mono, and the ear phones are stereo. I don't know if it will work or not.
Dec 16, 2007 | Dell DJ MP3 Player
DELL pOCKET dj
Hi
You can get one at batterytrader - click the link to go there - Dell Jukebox DJ battery for the Dell Digital jukebox DJ1st and 2nd, also the DJ20, - rechargeable replacement batteries
Nov 14, 2007 | Dell Pocket DJ MP3 Player
Ear Jack
Theres a good posibility that the solder connections are the only thinbg wrong with the connections BUT theres a possibility that the Printed curcuit board its self is a flex board and that the flex connections are torn. If thats the case you probably wont be able to fix the unit. If you can open the unit then you can look at the connections and see if its just plain old solder connections?? Good Luck
Apr 22, 2006 | Dell DJ MP3 Player
Dell Pocket DJ MP3 Player Logo
114 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
