Question about Cameras
Camera wont read memory card camera says memory card error and i have tried many other chips and it does not work.it also says that the memory card is locked.
  • 18 Answers
What kind of memory card is it? Look on the side and make sure the small tab is not in the "lock" position. This may solve your problem.
Posted on Dec 08, 2008
Camera wont read memory card error message say: memory card error, please check the card. I dont think its the card becaouse other devices can read it
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 17, 2010 | Panasonic DMC-TZ5 Digital Camera
I have a Bushnell trailscout 119900 and it wont accept any other SD card but the one that came with it. The one that came with it is only a 512 MB chip card The ones I have been trying to use are 2 GB SD...
Probably the first thing to try is formatting the card. There should be a function in the setup menus to do this. If it won't format or gives an error when you try the card may be incompatible. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. Some cameras have a capacity limit, and won't work with cards that are too large (in memory terms).
Oct 30, 2010 | Bushnell Trail Scout 11-9500c Digital...
Sony memory stick PRO duo 4gb card says memory full when empty
I would suggest formating the memory card through the options on your camera. If you reformat the memory card and you still get the same error then you have a bad card. Just like anything else the cards will break down internally over time.
Mar 07, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
The chip reads memory card error
They do go bad in rare cases...... buy a cheap card reader from radio shack and use your PC to try and read it. - or - find a buddy with a devise that takes the same card and see if his reads it. - or - buy a new card and test the new card in your devise......if the new card reads ok then your old card is bad
Jun 08, 2009 | Canon PowerShot A470 Digital Camera
Memory card not working? ( fuji finepix Z20fd Digital Camera)
Hi there.
When you start using a memory card, you must format the card in the camera first...using the camera menu. If you don't the camera won't read the card properly. Try that and I bet it will work for you.
Rob
Feb 17, 2009 | Fuji Finepix Z20fd Digital Camera
SD 215mb memory card reads ''memory card error''
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Nov 12, 2008 | Vivitar ViviCam 5385 Digital Camera
Memory card error
I think I know this one. This camera cannot read SDHC (High Capacity) memory cards - it can only read regular SD cards. Try using a standard SD card and see what happens.
Jul 22, 2008 | Cameras
Polaroid Memory Chip problem
Hey ashley131,
One thing that might be happening is your SD card is set to the locked position on the side of your card. If this is not the case you could try opening the card by going to My Computer and right clicking on the memory card icon, then left click on open, and if it opens copy all the files shown and paste them into a folder of your choice, and then try opening the files using windows picture manager. If this doesn't work there are memory card recovery programs you should be able to use to recover your images just do an internet search for memory card recovery software. Once you have saved your images to your computer I would format your memory card in your camera, and the card should be able to be used again. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 27, 2008 | Cameras
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Cameras Logo
155 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
