Question about Acard Technology (ARS-2030LD) DVD±RW Burner
Source disc empty
My dvd duplicator reads source disc empty. i just bought it in august. what can cause this or what do i need to do to fix it.
thank you,
  • reiko_frost Mar 13, 2009
    i just changed out the drive with a used drive and the readings say "source disc empty!!!" what dose this mean and how can i solve this?
  • Kal-El10128 Mar 15, 2009
    Just brought a dvd duplicator a couple of months ago and I also get a message that says "SOURCE DISC EMPTY". Can someone please shed some light on the subject. Thank You!
When trying to copy the message reads source disc empty
Does the disk drive play the disk? If not, the drive could be faulty. If not, then the disk can bec copy protected
Jun 13, 2014 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Acard duplicator comes up 'source drive not ready' it has been working fine untill now is it just a case of replace the disc drive or is it more serious?
Have you tried to upgrade firmware ?
If this is up to date and still causes function error try to Completely uninstall all software for it and reinstall....
May 15, 2012 | Acard ARS-2030PC 1-to-3 Target USB Card...
I have a Pioneer CD/DVD Duplicator 8 drives. Recently no matter what disc I put in as the master. It tells me I have a mad Master Disc. Obviously all the media can't be bad. When this messgae pops...
The 3rd drive is the master now. If you want to change back to top drive, go to #8 "select source" and use up/down key change to " drive 1 " and save. for more detail, please read the user manual page 21 and 22.
For VPD system,if the top drive defected, the system should auto assign 2nd drive as source, but your system pick up 3rd drive as source drive, I suggest you check drive 1 and 2 before make copy.
Jan 04, 2011 | Pioneer 1 to 7 DVD Duplicator: SharkCopier...
I put a dvd in the dvd rom and blank dvds in the other and hit copy and it goes to preparing and the says that the source is not ready.
The "Source Drive Not Ready" error message indicates a problem with your master disc. There is a function on the duplicator called "Prescan" on the duplicator that can check your master disc to make sure it s a "good" disc suitable for duplication.
Hope this helps and if you have any other questions, comments or concerns, please contact us @ 877-686-8868 x208 for technical support.
EZ Dupe Technical Support
Oct 14, 2010 | EZ Dupe (EZD1TDVDNEC) DVD±RW Burner
Microboards DX1 input problems
Microboards' New DX-1 Disc Publisher to Ship Microboards’ New Print & Burn DVD/CD Duplicator Ships
Industrial quality of DX-2 and Print Factory in a Compact Package with the DX-1
Chanhassen, MN, August 17, 2004 —Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
You've got an expensive unit (see below for Press Release), with a built-in CD/DVD reader/writer.
Given that your unit could be six years old, it's possible that the reader/writer has "died".
It seems to be a "stand-alone" unit -- not something that requires either Mac OSx or Windows XP/Vista/7 to operate.
I'm guessing that _ANY_ IDE (not 'SATA') HP-brand reader/writer, provided that it has a "LightScribe" capability, could be purchased, and could be inserted to replace the "dead" reader/writer. For about $100, it's worthwhile to try this "substitution" to revive your unit.
____________________________
Chanhassen, MN, August 17, 2004 — Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
Jun 10, 2010 | MicroBoards DX-1 Publisher Printer
Machine won't duplicate CD or DVD...A good disk is in source disk area but it reads Source Disk empty or Source Disk not ready....
The solution to this is simple. On the menu when you see that the # of MB is 0MB. Press the Arrows that change the menu option to #8 Select Source. Change this back to your original DVD-Rom or RW drive.
Nov 07, 2009 | Computers & Internet
Bad disc
Try cleaning the lens yourself. Before taking drastic measures as replacing stuff, try cleaning the lens on the DVD/CD Drive. You will need to open the unit and also open the DVD/CD case. Make sure you do this while the unit is unplugged from a power source. Locate the lens that reads a dvd/cd. Now get a cotton swab and moisten it with isopropyl alcohol (rubbing alcohol) and gently rub the lens clean...use the other dry end of the cotton swab to rub it as well. Try not to use too much alcohol on the swab and not too much force when rubbing. Let it dry for a minute or 2 and screw the unit back into 1 piece. Moisture, cigarette smoke, insence smoke, and dust can cause a barrier between the DVD/CD and the reading lens and by doing this you will either fix the unit or know that it is a problem that will need replacing. Good luck!e lens yourself manually
Jun 23, 2008 | Cyberhome CH-DVD 300 DVD Player
Targer drive not ready.
"Target overflow" just means that the disc being used to make the copy doesn't match in size. "4.7GB" to the master disc. Sometimes this occurs when you make a mistake thinking the disc in the copy slot is a DVD blank but it may be a CD-R blank(by accident) or sometimes the Master disc is a BD-R and trying to copy to a regular DVD-R (won't fit)
"Source drive not ready" is when the Master disc keeps spinning in the attempt to read. The "culprit" alot of times is the brand, or scratched, dirty, corrupted discs.
Make a copy of the master again (if possible and on your PC with a different brand of disc) then use the new Master to make the multi-discs you want.
"Target drive not ready"
is when a disc with information already on it, is in the copier (can't copy over it) sometimes we make mistakes and put the Master in the copier and vice versa : )
or no disc in it at all, and or some sort of incompatible blank media.
I have a 7 disc duplicator by Pioneer and I found that in the last few years since I've had it (since 2005)
I ran into the above situations alot.
I use it as a standalone (not hooked up to any PC etc)
It still works great but I find that was having a brand name issue with the discs; certain discs that it used to read in the Master/Source drive like Taiyo Yuden, Memorex, Ridata, SKMAX, and Phillips, suddenly don't want to read properly when inserted. The discs keeps spinning and then when you press "copy" it says "Target overflow" or "Source drive not ready" I found that solution I mentioned above with the changing of the disc brand helps fix the situation. I didn't want to hurt my brain trying to figure out what it could be as I use my duplicator for business and time is money.
Through trial and error I end up just making duplicates from my PC on different brands (cheaper unknown brands work fine) and then using the "new master" made from these is the only way I can duplicate..weird!
P.S sometimes the lens may need an old fashioned cleaning with a lens cleaner or Dust blower.
Once in a while one or two of the doors get stuck even when all 7 discs are completed...just take a q-tip with vaseline and put it on the track wheel for some lubrication and the door will open up easier.
Just some tips from someone who's had their player a long time
Hope this helps anyone in need out : )
Jun 20, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Teac 1x1 dvd duplicator dvw-d11
This seems to be a memory/cache problem - increase (double) your cache size .....
Mar 19, 2008 | Computers & Internet
Acard Technology (ARS-2030LD) DVD±RW Burner Logo
551 people viewed this question
Top Acard Technology Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Saeid
Saeid
LP
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
