Question about Aiptek Pocket DV 5900 DV Digital Camcorder
Aiptek5900 The record button is stuck down. Any suggestions?
Unscew the camera and wedge something between the record button and the green wirey base until it loosens
Posted on Mar 28, 2008
SOURCE:
Stuck record button
You can find plenty of YouTube videos about taking cameras apart, if you want to clean out the button area yourself.
Here are links to some
Meanwhile, you would probably do well to send it to a Canon service center or a reputable camera shop for cleaning by people with experience in taking it apart and putting it back together.
Aug 02, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
The Stat button is stuck down, have tried popping up with a paper clip but no good. Any suggestions, none of the other buttons will work with the STAT button stuck!
Hi
take out all 4 batteries take alcohol 2 drops on the button
push the button a few times it should help unless there is glue inside than yo must open the calc and clean all the buttons
Sep 12, 2012 | Texas Instruments TI-83 Plus Calculator
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
Record button is stuck and cannot be pushed down.
Make sure the tape is not protected or broken tap on bottom of tape
Dec 08, 2009 | Sony Pressman TCM-929 Desktop Cassette...
My ipod has a record control, and I can't record anymore. It appears to be stuck
Dear, there is button for record, it is not functioning properly because it is not doing the right job, if you will try to fix it, there are great chances of future damage, because of the mini-circuit in this technology. I suggest you to visit repair shop for assistance, it would be better than fixing it yourself.
Best regards.
May 27, 2009 | Cowon System iAUDIO X5 MP3 Player
RECORDING LEVEL IS NOW INOP
Wide open as in you cannot control the gain? If so I would suggest controling it from your mixer using a second zone or record out.
Dec 09, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Magnavox TV/VCR COMBO
Im thinking that maybe you a have a timer recording set. The whole unit wont function at all if you turn it on via power button (remote or unit). There should be a button at the top of the remote called 'timer set' pressing this will disable that mode and allow complete use of everything. but make sure u press timer set again when powering down, otherwise simply turning off the machine will leave the timer recording disabled.
Oct 17, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
E200 Voice Recorder gone mad!
Maybe the recorder button is getting stuck? You can disassemble the unit and see if anything is in the way.
Sep 06, 2005 | Casio Cassiopeia E-200 Pocket PC
Aiptek Pocket DV 5900 DV Digital Camcorder Logo
60 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Jose Ma DM.
Jose Ma DM.
Tom Chichester
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
