I have a behringer djx 700 and i got an efx 1000, and would really help me if you no how the best way to connect it to the mixer my dj setup is 2x pioneer cdj 1000 mk3 1x behringer djx700 1x pioneer efx-1000 cheers Gary
  • 71 Answers
Ok has the mixer got a send and return phono sockets if it has not the efx unit will have to be wired between your mixer and amp.this is not the best way . what does the efx / effects unit do .
Posted on Dec 08, 2008
I cannot hook my Behringer mixer to the Pioneer EFX 500 it's not working
I presume you are using the send and return inputs on the EFX500.
Make sure the effect selector, CH Selector and EF On/off are set right. then use these in the insert chain of the mixer for the channel/bus/sub you want to use the effects on. Remember on the mixer it will be tip send and ring return. It would be useful if you said which behringer mixer (they make an awful lot of them from complex digital to simple DJ) and what you are trying to do with it.
It is clearly explained in the Pioneer manual under basic connections. If you are a DJ you may not be familiar with the Insert concept so get yourself down to a professional sound/PA outlet or Radioshack / Maplin and ask for a pair of insert leads.
May 23, 2016 | Behringer Music
Djx 750 - no power - transformer dead?
Actually, you may be in luck. A burned cap means that it has done exactly what it's supposed to do. So...you might stick an identical one in there -- it's a 0.1 uF cap, and you can find these at Radio Shack (0.1 uF 50V) or online. They are cheap, so give it a shot.
Feb 16, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer djx 750 headphone
What is the problem. A description might help get your questions resolved.
Jan 22, 2013 | Behringer DJX750 5-Channel DJ Mixer
I just purchased the behringer djx 700, and the channel 2,3,4 are all distorted when i play music. Even when i listen to it through headphones you can still hear the heavy distortion. What can i do to...
You are probably overdriving the inputs. You haven't told us the source of the inputs and we can't guess where they may come from. You need to read the manual and make sure your source outputs are within range of what this unit requires.
Jul 17, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
I replaced the transformer and fuse which is in a sealed compartment above the power supply connection in djx 700 (behringer) and still have humming in the new transformer
Transformers rarely fail... you wasted money on that... Likely one of the rectifier diodes/module or filter caps has shorted. Continued use will burn out the transformer. It is humming because it is overloaded with failing components.
Jul 02, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Im thinking about buying a djx750 and have rokit 5 monitors. would this work? what is the best way to connect them, to have good sound? it is just for a home dj setup, all on one desk, two cd decks,...
Here is alink to the manual:http://www.behringer.com/EN/downloads/pdf/DJX750_P0956_M_EN.pdf You should have no problems hooking them up (RCA to RCA). I've been using a Behringer XenyX1222FX board in my recording system for about 4 years now and have been quite satisfied with it's reliability. Try to find a dealer who will demo the mixer for you.
Aug 24, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I plugged my djx 700 into a club system, within minutes it was boiling hot, it did not stop working but i only used it for 30 minutes, i'm using it for 7 hours on friday night in the ame club, will it stop...
Suspect a ground problem someplace in the system.
Make sure your system is plugged into exact same recepacle that anything else you connect to is plugged into.
Also make sure a spot light is not heating it.
Oct 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
142 people viewed this question
 Grubhead
Grubhead
