Question about Dell Inspiron 9300 PC Notebook
DELL Inspiron 9300 1Gbyte RAM, that has a CPU race condition
I have a DELL Inspiron 9300 1Gbyte RAM, that has a CPU race condition.
CPU running at 100%, the fan blowing at max speed. It unable to service any other tasks, basically unusable.
At first I thought it was a virus. Much of the system time was spent by the antivirus software. But the condition persisted after the virus scanner was suspended. Rather than trying to untangle a bad virus, I reinstalled the entire OS going from XP SP1 to Vista SP1.
While it is at least usable now, the CPU continues to race and the fan won't step down. Is there a hardware issue that can cause this?
    Scholar:
  • 55 Answers
Do you still have the Dell Resource CD? If so, run the 32-bit diagnostic tests by inserting the Resource CD or Drivers and Utilities disk and press F12 when you start the computer (as soon as you see the DELL logo). Then boot from the CD-ROM. Run the Express Test. Check for error messages. Go to support.dell.com and search for that error message or codes.
Posted on Dec 09, 2008
Why will my fan not run during use but i hear it when the computer powers up?
Fans, mainly the CPU fan, have a speed control which slows the fan down. This is usually controlled by the BIOS. The speed is based on temperature of the CPU. If it's cool with little load the CPU fan will run very slowly and you won't be able to hear it. On startup all fans ramp up to 100% until the BIOS takes over and slows the fan down.
Jul 27, 2014 | Dell Inspiron 531s Desktop Computer
Assassins creed 3 on dell inspiron 640m
CPU: 2.66 GHz Intel Core 2 Duo E8200 or 2.66 GHz AMD Athlon II X4 620 CPU Speed: Info RAM: 2 GB
Not enough RAM!
OS: Windows Vista (SP2) / Windows 7 (SP1) / Windows 8 Video Card: 512 MB DirectX 9.0c-compliant with Shader Model 4.0 or higher (GeForce 8800 GT or Radeon HD 4850) Sound Card: Yes Free Disk Space: 17 GB
Jan 11, 2014 | Dell Inspiron 640m Notebook
My dell Inspiron 1100 runs slow
Change the RAM. for a good one. And set it up to Windows Clasic View.
Check vent.. - is it clean, and in good condition ? Cream between Processor and radiator...- isn't dry?
Oct 14, 2012 | Dell Inspiron 1100 Laptop/notebook
I have a Dell Inspiron 530. Was getting 2 quick beeps on start up and loud fan noise. I replaced the cpu fan but the one I bought did not have the right plug for the motherboard connection. I had to modify...
This model (as well as many other Dell desktops) has a DUAL SPEED CPU fan. If the motherboard detects that the CPU temp is running hot it will increase the speed of the CPU fan to lower the temp of the CPU. You should do a Google search for the correct CPU fan and purchase it and install it back into your computer.
Aug 28, 2011 | Dell Inspiron 530 Desktop Computer
Pc wont start when turned on and the fan runs at high and it beeps 4 times
The RAM in the motherboard is not seated properly, it might have slightly moved out of the slot or the physical contacts is not proper.It can happen while moving the cpu or may be due to any other shocks. Open the CPU tower. Remove the RAM and place it back in the same slot after dusting the slot. It will work for sure 100%
Please rate the solution and Write a testimonial, if my solution helped for u.
May 23, 2011 | Dell Inspiron 530 Desktop Computer
My Dell cooling fan now runs at a high speed and the computer will not turn on. I robbed one from an older Dell, and got a message that the (new-old) fan wasn't working, (The plug was smaller then mine)but...
The cooling fan racing is a symptom of a No Post state in the Motherboard. The Power LED and diagnostic LED indications would be helpful in resolving your issue. If the power LED is flashing Amber, the power supply is suspect, solid Amber points to the motherboard or something connected to it. The DIAG LEDs 1234 on the front or ABCD on the back give more specific information.
Initial Impression, is motherboard failure, post the DIAG and Power LED indications for more exact diagnosis
Mar 03, 2010 | Dell (6F858) Cooling Fan
Dell inspiron 8500. fan comes on high speed & system locks up, requiring turn-off at switch & reboot. what gives?
Normally fans racing at full tilt on boot indicate either a severe cooling issue or an indication of a NO POST.
See if you can take some canned compressed air, can blow in and out the intake and exhaust vents for the CPU cooling and see how much dust you can get out of the system
If no change, then remove all times you can tale out (Battery, RAM, WIreless Card, Modem, HDD< OPtical Drive) and see if the system has any change in indications.
If no change, likely a motherboard. If changes, add RAM back, see if system will post and you can access BIOS. Continue adding parts till you ID a faulty one.
Jun 05, 2009 | Dell Computers & Internet
Laptop running hot - Fan cycling on and off every 10-20 seconds
My guess is that CPU fan, it there is one, is not working properly and your computer is heating up. Is it turning off, too, occasionally after a period of time? Suggest a new CPU fan.
Jun 14, 2008 | Dell Inspiron B130 Notebook
RAM not running at full speed
Go to page 33 in your manual, see DRAM Clock/Drive Control & press enter. You can tweak your memory to run faster however your manual suggest not too. Hate to see you burn it up. As you will see everything is set to Auto:
Max Memclock (Mhz) [Auto]
1T/2T Memory Timing [Auto]
CAS# latency (Tcl) [Auto]
When DDR Timing Setting by is set to Manual, use this item to set the DRAM frequency. Would be nice to have a side panel fan blowing on your memory.
Link to your board.: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=455&DetailName=Specification&MenuID=1&LanID=9
Jan 04, 2008 | EliteGroup K8M800-M2 Motherboard
Dell Inspiron 9300 PC Notebook Logo
278 people viewed this question
Alun Cox
