Question about Cameras
Have a D-150 1.3 MP and suspect batteries were put in with reverse polarity. Is this worth fixing? How?
  • 18 Answers
I wouldn't bother. You can get a equivalent camera brand new for probably $20, I just picked up a 6MP canon cam on ebay for a little over $100 that works like a champ.
Posted on Dec 08, 2008
When wiring reversed polarity. now it not work. is there fuse in the unit some where?
Fuse is there, but more damage is suspected. Transistors damage easily and capacitors will short when subjected to reverse polarity.
Jan 01, 2016 | Vector Electronics - Others
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
I think I reversed polarity and now my charger won't work. How can I fix this?
Not sure what you wanted to charge, but with reversed polarity most of the time the device connected, will be "dead". It could be you destroyed the battery(s) When that is all, a new battery(s) should solve the problem. Only when the reversion, caused a shortage, that could have blown a fuse. When you connected a camera or another device, it could be that or the internal battery is defect.
Apr 03, 2015 | Cameras
I accidently installed the battery reverse polarity,momentarily only. Now installed correctly and no power at all. Suspect fuse? I can't find the 30Amp fuse. I have located the spare one and the 10amp...
Look at the end of the red cable coming from the battery. There will be a metal strip bolted to a plastic block. That is the main fuse. If it's not there it will be in the plug that goes on the starter relay.
Sometime when reversing polarity on the bike you can damage the engine management system. Check everything carefully. Hope you didn't. good luck.
Mar 17, 2014 | 1999 Honda CBR 600 F(4)X
Club Cart Golf Cart Reverse only
You don't have it connected right. The DC motor is 'polarity reversed' to change direction. That's what the controller does is reverse the polarity to the motor to change direction. If the motor is still working in reverse, then the controller is 'probably' okay. Recheck the connections you made.
Sep 03, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
AUDIOCODES MP-118 FXO
Hi, I am using Audiocodes MP-118 FXO too
Man, check the Reverse Polarity.
1st.- Go to Protocol Management
2nd.-Go to Advance Parameter
3rd.- Go to General Parameter
4th.- Go to Enable Polarity Reversal and select ENABLE
5th.- BURN and RESET
You have FAS calls, because Reverse Polarity is disable.
Lucky
May 28, 2009 | AudioCodes MP118 Analog Modem
Won't work
oh no maybe you used different adaptor some adaptor have reverse polarity. check the adaptor before plugging it..if you using variable voltage set to 3v then adjust also the polarity. the polarity should match the polarity of your camera.
Feb 05, 2008 | Kodak EasyShare C875 Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
