Question about Optoma EP738 Multimedia Projector
Optoma EP739 overheats and powers down after 30min use
My EP739 shuts down after 30min of use in normal room temp. This started after one nights use in a night club that was filled with smoke from a smoke machine. my thought was that the fan is running slower due to sticky residue? i could do with some advice on this perhaps where to buy and how to replace fan? is there more than 1 fan? any thing else it might be?
thanks
richard
Benimur
  • 6966 Answers
SOURCE: no signal optoma ep739
One good thing is that you are running XP. Will work on the premise (that you have posted) worked before and the driver (ForceWare91.31) was the only thing changed.
Let's try the easy ones first. Activate twin/dual view in your Display Properties. Right click on any clear area of your desktop, click on Properties, click on Settings tab, select monitor 1 or 2 depending which is your primary and which is your projector. Check (or uncheck-whichever works) on box "Extend....". Apply, OK.
or
do the same with nView Properties.
The hard ones are registry and/or inf editing, though I am reluctant to even suggest.
Incidentally, there is an application that is supposed to facilitate twin or dual view configuration, UltraMon. This may be better/safer way to address your concern.
If all else fails, you may have to rollback/downgrade your driver.
Cheers.
Posted on Jan 20, 2008
SOURCE: optoma ep739 won't power up
The lamp cover has a disconnect that won't allow power while the cover is off. Sometimes the piece of metal gets bent out of place.
Try removing the cover for the lamp, and bending the little piece of metal forward.
It worked for me!!!!
Posted on Nov 27, 2008
SOURCE: Optoma EP739
The lamp cover has a disconnect that wont allow the unit to power on while the cover is off.
Try taking the lamp cover off and bending the little piece of metal you find underneith.
It worked for me.
  • 10 Answers
SOURCE: we have a optoma ep739 used at our local football
take the lamp out, there is a fan directly looking to the lamp... clean it with a compressor. and after that at the menu of projector there is a place called 'High Altitude'. turn it on. And it'll be fine...
Posted on Mar 02, 2010
Testimonial: "seems to have cured the promblem,many thanks"
  • 13 Answers
SOURCE: OPTOMA EP739 KEEPS OVERHEATING
Clean out the filter.
Posted on Feb 14, 2011
My projector shuts off after only thirty seconds. and a red light turns on. I don't think it's over heating because it's not hot. Can anyone help?
HI
PLEASE CHECK FIRST LIGHT INDICATION ? IF TEMP LIGHT PL CHECK FAN IF ANY OTHER PL POST ON FIXYA .
M.R.MUMBAI & DUBAI
Aug 28, 2010 | Optoma EP739 Multimedia Projector
We have a optoma ep739 used at our local football club;but whenit gets warm it cuts out until it cools down;isthere any filters that need cleaning
Mar 01, 2010 | Optoma EP739 Multimedia Projector
On my optoma H77 I am replacing a burnt out bulb with a New one. The ''TEMP'' light blinks immediatly without the projector getting up to normal opporating temp. Is there a ''Reset'' button ?
clean out the projector with canned air to get rid of the dust that could be causing it to overheat. also make sure the fans are spinning. if it still blinks, replace the temp sensor. if it overheats alot, the sensor will wear out from excessive heat.
Nov 07, 2009 | Optoma H77 Multimedia Projector
After running for a while the projector smells hot
Hey,
thats completely normal, make sure the fan and ventilation is working properly so it doesn't overheat.
Feb 18, 2009 | Optoma EP739 Multimedia Projector
Optoma ep739 color was going greenish so i replced the bulb and now it seems to be getting no power at all? i tried several outlets and still no power, no flashing light, no led, nothing. Any suggestions?
These units have many safety interlocks. First make sure that all of the doors that you opened are replaced correctly. If not, the interlocks will prevent any power from getting to the unit. Update this with what you find.
Dan
Jan 29, 2009 | Optoma EP739 Multimedia Projector
Optoma EP739
It worked for me.
Nov 01, 2008 | Optoma EP739 Multimedia Projector
Powers off and lamp never comes on (new lamp tested in other ep739)
The lamp might be burn out or you do ot have the computer in the right plug and the right input slected.
Jul 23, 2008 | Optoma EP739 Multimedia Projector
Optoma EP739 Projector Overheating
Set the projector to "high altitude mode." It will be noisier, but won't overheat. I wonder whether using one of those $10-$20 laptop coolers underneath it might be a quieter solution.
Mar 09, 2008 | Cameras
Optoma EP738 Multimedia Projector Logo
423 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
