Question about Presto HeatDish Compact Heater
The unit does not shut off
When the switch is in the off position it still comes on
  • 4 Answers
Turn knob to the right, all the way. Do not force, be gentle.
Posted on Dec 16, 2008
Ice maker moves forward when you push glass for ice. Then you can't shut the door and no ice comes out.
is the acess door on the icemaker in the down position? it may have a micro switch on it that is not allowing the unit to dispence..
Mar 04, 2014 | Jenn-Air JCD2389G Side by Side...
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
Sep 28, 2008 | Kitchen Ranges
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    Panasonic inverter microwave: when i shut off the lid, turntale automatically rotating
    When you close the door the turntable comes on? Almost all have a safety switch in the side of the wall where the door closes, An inspection inside the unit will show if switch is damaged or out of position which could cause this problem.
    Dec 17, 2012 | Panasonic Microwave Ovens
    I have a 1999 Chevy Malibu LS. Occasionally when I turn the key to the off position the engine will shut down but the ignition switch appears to be in the acc. mode what causes this?
    key switch could be time with the car running,keep pressure on key as if you were trying to pull it out and turn to the off position slowly, this will let you know if it is going past the lock position when you are shutting car off.The keys should come out just as you come to the off position, if they come out any earlier, the switch is bad.
    Nov 08, 2012 | Chevrolet Cars & Trucks
    I have a 460 husqvarna Rancher and the shut off switch does not work? What could it be?
    There are two wires to the red rocker switch, one is from the ignition unit the other is an earth return, the wire from the unit slots into the side of the red plastic switch it is moulded to take the terminal, the other wire connects to a chrome strip, this strip is the earth return, as the red switch is placed in the stop position it touches the wire from the unit to the earth strip and stops the engine, make sure the wire has not come adrift from the side of the switch, if not check both wires down to the unit with a continuity tester.
    Nov 05, 2012 | Husqvarna Garden
    Left turn signal in 95 jetta wont shut off
    If even after the control switch comes to resting position the turn lights are flashing then it can be a short within the switches contact or if the flash is constant it can be a fault in the flasher unit.
    Mar 15, 2012 | Cars & Trucks
    Not used for 2 years. It will not start.
    Engine will
    not start
    1. Low on fuel or oil. 1. Add fuel or oil.
    2. Ignition switch in "Off"position. 2. Turn to "ON" position
    3. Faulty spark plug. 3. Replace spark plug.
    4. Choke in wrong position. 4. Adjust choke accordingly.
    5. Fuel shut-off valve in closed position 5. Open fuel shut-off valve.
    6. Unit loaded during start-up. 6. Remove load from unit.
    7. Spark plug wire loose. 7. Attach wire to spark plug.
    Apr 23, 2011 | Porter Cable 5,500 Watt Portable Generator...
    In off position does switch make or break to ground ?
    In the off position it breaks the ground that is how it shut it down.
    Jan 21, 2011 | Mowtownusa Snow Thrower Starter Switch for...
    Braun 7680 won't shut off
    Every time I have seen this problem, the switch apparatus was broken and had to be replaced. The switch/trimmer assembly comes with the case and can be found at See link below
    Apr 10, 2010 | Braun Health & Beauty
    Presto HeatDish Compact Heater Logo
    43 people viewed this question
    Top Presto Heating & Cooling Experts
    Mack Baxter
    Starnley Johnwells
    Starnley Johnwells
    Paul Carew
    Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
