Question about Sport & Outdoor - Others
Having difficulty getting my Indy Trail snowmobile started
It turns over, but doesn't start. Has clean spark plugs and fresh gas
Pull it harder
Posted on Jan 28, 2009
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
I reringed a polaris indy sport with a indy 500 engine in it, now the gas will shoot out of the spark plug holes. Is the fuel pump diaphram bad? Or are BOTH needels stuck? Or?????
SOUNDS LIKE THE ENGINE IS BADLY FLOODED, SHUT YOUR GASS OFF AND REMOVE THE PLUGS, THAN PULL IT OVER UNTIL IT IS UNFLOODED. IT SOUNDS LIKE THE NEEDLES ARE STUCK IN YOUR CARBS
Dec 10, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Feb 16, 2010 | Polaris New Genuine Polaris Snowmobile...
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
Snowmobile
First off, you need to put this under a different product.
For another, check the battery before you ask dumb questions!
Most efi sleds use a battery. Check it.
Feb 01, 2009 | Polaris New Genuine Polaris Snowmobile...
Indy 500 motor knocks
could be bad gas. try running fresh gas. if that dont work you have internal problems. make sure it is firing on both cylinders though. when you start it cold you can feel if one is running hotter than the other. do a compression test. 120 psi is normal and no more than 10 lbs difference between cylinders. if one is low motor needs a rebuild
Jan 20, 2009 | Polaris New Genuine Polaris Snowmobile...
Cant get my snowmobile started
you need to remove the old gas and replace
drain gas line if you can get to the carbs use starting fluid
( remove spark plugs and observe also clean with gas and wire brush
also while you have the plug out put the metal side of the spark plug (where you woud turn with a wrench) and turn over with ignition switch
to make sure u are getting a spark
good luck and happy snow mobileing
Jan 06, 2009 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
57 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
