Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
My Husqvarna 350 is getting fire and fuel but won't start.
I had the same problem on a 353, i knew all parts were good had fuel and spark but would not start. Read a few forums on the net and found out that if the chain brake is locked or jammed they will not fire. My brake was not on but I had just tightened the chain on mine before the problem so slackened it right off and it started after a few pulls! I must of over tightened the chain hence problem.
Posted on Jan 28, 2009
    Problem Solver:
  • 17 Answers
Try removing your spark plug and inspecting the gap. You may need to blow out the gap if its fouled, or replace it altogether. Also, check your air cleaner, and make sure that your saw isnt getting TOO much fuel (too rich of a mixture, and it wont ignite).
Posted on Dec 08, 2008
Husqvarna 223L won't start
I would first take the spark plug out and see if the tip is wet, it could very well be flooded.
second of all I'd try putting fuel directly into the carb (if this helps you'll most likely need a carb kit or maybe even a new carb)
May 30, 2013 | Husqvarna 223L
I just bought a used 350 husqvarna chain saw fires up n stalls right away put new premium gas in it
Start with a few simple things, replace the fuel filter in the fuel tank, check the fuel hoses for signs of leakage, replace if required.
Dec 22, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Husqvarna 350 bt won't start
Do you have good compression, good spark and is fuel getting into the cylinder.? More information would help diagnose the problem.
Jun 03, 2012 | Husqvarna BACKPACK BLOWER 350BT
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
I have a model 336 Husqvarna chainsaw and it won't start. Put fuel into open plug hole replug, then turn it over it fires until the fuel runs out & won't restart & has full tank, obviously...
There has to be a kink in your fuel line ,or some blockage. Dump the fuel out ,then disconnect the gas line and try to blow air through the line.
Sep 04, 2011 | Garden
My model 350 chainsaw has spark but will not fire. yes there is gas in tank and i used starting fluid but no go..
Is the plug wet when you take it out ? Is the fire blue and a good arc across it ? I always dip my plug in gas if it is dry, put it in, throttle wide open and if it fires up after a few pulls its not getting fuel. Be careful eith that ether, it will hurt you.
Oct 27, 2010 | Husqvarna Garden
350 chainsaw will not start and run, getting fuel
check set screws on the side of carb turn the all the way in the turn out till idles or check the screen in the muffler
Feb 03, 2010 | Husqvarna Garden
Husqvarna 350 geting fire and gas but wont start
Have you tried cleaning the air filter? The carburetor fuel inlet may have screens plugged with sawdust as well. If you have spark and fuel and AIR you should get fire(combustion)
Frank
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
210 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
