Question about Sony STR-DE595 Receiver
Sony SRT-DE595 I have Sony SRT-DE595 and Cerwin Vega 5.1 speakers Subwoofer AVS SUB8 speakers works only subwoofer dont start working and i have Y cable if someone can me help :) sorry my english bad
  • 1 more comment
  • WRC08 Dec 08, 2008
    subwoofer YES and dont work
    subwoofer YES and dont work still
    i readed one place AVG Sub8 subwoofer power light going green when get signal only i have all time red
    then subwoofer and srt-de595 dont get signal
  • wittwicky
    wittwicky Jan 05, 2009
    I have a similar problem connecting my Sony STR-DTG800 with a Yamaha YST-SW90 subwoofer.  I tried connecting the subwoofer using the "B" front speaker jacks on the receiver to the input speaker jacks on the subwoofer.  The subwoofer light stays RED, standby mode I believe.  The PRE subwoofer output from the receiver is just one RCA jack -- how can you connect that to the Input jacks on the subwoofer?  The subwoofer Input 2 is TWO (2) RCA jacks, left and right.
    Any help is greatly appreciated.  The Sony and Yamaha support web sites are a joke...useless.
  • 492 Answers
Go into the speaker setup menu and turn subwoofer to YES
Posted on Dec 08, 2008
  • Sean Johnson
    Sean Johnson Dec 08, 2008
    Perhaps try a different cable. I am not sure on your brand of sub, but sometimes the cables do not carry the signal correctly. I will do some research and see if I come up with anything.
Bad plate amp Subwoofer Plate Amplifiers
Feb 18, 2014 | Cerwin Vega LW12 Subwoofer
The subwoofer starts to make a loud thumping sound
Remove the signal source and power it on to see if the problem occurs without any input signal. The problem could be in the receiver and not the sub
Dec 08, 2013 | Cerwin Vega Avs-sub8 150 Watt Amplified...
What is the omhs of a cerwin vega avs sat4 surround speaker
According the the Cerwin Vega manual for this model and others, all speakers in the system are rated at 8ohms. This includes the Sat4 Surround Speaker and all other channels.
More information can be found at Cerwin-Vega's service and support page at:
You can also call them for information as well.
Mar 19, 2011 | Cerwin Vega AVS-5.1 System
I have no idea how to connect these speakers all I have is the wires for the 5 speakers and a power cord for the sub any help please?
You have not mentioned -- connect it to what ???. Assuming that its an AV receiver. Start by connecting the front three speakers to the the amplifiers speaker sockets labeled Left front / Center / Right Front. These are connected using three short wires. Then connect the two surround speakers using the pair of long speaker cables. You will need a RCA to RCA cable to connect the subwoofer to the Receivers subwoofer preamp out.The subwoofer also requires an A/C wall socket to power it.
Mar 08, 2011 | Cerwin Vega AVS-5.1 System
Cerwin vega avs sub8. no power. changed blown fuse and still nothing. no power light indicator. unless led light bulb blew which i believe to be unlikely it has no power. any ideas
I got the same problem, my sub was working perfectly and suddenly one day it did't turned on, so I think it is the protection from the internal transformer, it needs to be changed but I don't know the model, if someone else knows I would appreciate the info because it is a really good subwoofer for the size...
Jan 07, 2011 | Cerwin Vega AVS-5.1 System
Cerwin Vega do I connect
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
No sound coming out of speakers on my cerwin vega
It will be easy to pin point the problem. If your satellite speakers have been connect through the sub's in and output speaker connectors, disconnect them and connect them directly to the source of sound. If the speakers work its the crossover inside the sub enclosure. If the speakers do not work the speakers are blown.
Apr 28, 2010 | Cerwin Vega AVS-5.1 System
I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service:
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
Sony STR-DE595 Receiver Logo
234 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
